Update on group buy of larger exhaust housing for tc78
Old 02-14-2011, 02:52 PM
  #101
Johnv's Avatar
Originally Posted by CarsandWomen
John which housing are you going with and is it for the Commodore?
I already have a 1.32 AR
got the last one turbonetics made...
yes its on the Commodore, which is pretty similar to the GTO but 4 door.
I have also stepped my downpipe straight to 3 1/2" off the turbo which made a noticable difference in spool, so I would go 3 1/2 outlet on the housing if you can squeeze the bigger downpipe in.
I have just picked up a damaged Turbonetics T76 Thumper, was going to have the compressor housing/backing plate machined to fit the TC 78,
but now thinking of just having it rebuilt and swapping turbos.....
Old 02-14-2011, 02:56 PM
  #102
Johnv's Avatar
Originally Posted by HydroStream6
Did anyone ever find out if the turbo inlet flange and vband exit will be in the exact same locations as the original Turbonetics housing? I understand the housing itself may change size but what about the flanges? And do we have a "current price" with the 10 orders so far?
Even the one I got from Turbonetics was out by a couple of mm , just had to cut and reweld the "V" band for downpipe.
Old 02-14-2011, 03:00 PM
  #103
Johnv's Avatar
Originally Posted by spaz1
Hey Is your .96 undivided. I got a 1.15 but for some reason they sent me a divided housing. I have major back pressure and was wondering if the .96 undivided would get rid of some of that.. not sure what I should go with... or who to listen to anymore....
Lmk if you want to sell it.
Thanks,Chris.
Your 1.15 housing will flow more than the .96 undevided.
your best bet is to jump in on the group buy and step up to 1.32 or 1.52 ar housing.
Old 02-14-2011, 03:03 PM
  #104
yelo04goat's Avatar
sooo.. 1.32 and 3.5dp is the way to go is what your saying what did you shift at?
and yea get in on the group buy help everyone help you
Old 02-14-2011, 05:01 PM
  #105
Johnv's Avatar
works well for my combo - 383 m6, but hey the 1.52 ar may be better still...
I shift at 6500 rpm (mild turbo cam).
If you have room and don't mind fabbing a 3 1/2" downpipe there are gains to be had. if not stick with what you've got.
If you have an auto and converter you will get away with a bigger AR housing then an M6, lag will be less of an issue.
Old 02-14-2011, 05:38 PM
  #106
HydroStream6's Avatar
FWIW I've gone 135mph in the 1/4 on both a .81 and .96 housings with the TC76 with a 4200lb race weight. 3" downpipe 15psi boost on a 370 through a 4L80e. I really hope you guys see some good gains, I just have my doubts that you'll gain much. I sincerely hope I am wrong though.
Old 02-18-2011, 01:44 AM
  #107
yelo04goat's Avatar
bump up for others and updates!!!
Old 02-24-2011, 07:55 AM
  #108
yelo04goat's Avatar
anyone hear anything ??? im willing to just buy someones housing i want something bigger then the .96 i got
Old 02-24-2011, 10:03 AM
  #109
Coal Mining Director
onfire's Avatar
Here is a crude estimate of flow gains of different AR's on a similar (but not exact) turbine....just to give you a rough idea of the improvement....
Attached Thumbnails Update on group buy of larger exhaust housing for tc78-gt4094r_turb_e.jpg
Old 02-28-2011, 09:04 PM
  #110
b20forlife's Avatar
ill buy someones .82 or .96 housing. pm me a price
Old 04-03-2011, 12:28 AM
  #111
CarsandWomen's Avatar
TTTop
Old 04-03-2011, 09:46 AM
  #112
yelo04goat's Avatar
i emailed comp while i was still on deployment.. guy said no one ever sent in a turbo for mock up... so i guess the bottom done fell out of this... i am just goin on with the .96
Old 04-04-2011, 07:44 AM
  #113
well I pm'd Zac about it and he sold his TC without ever sending it in. He didnt tell anybody this so nobody else did either.
I work nights and these next two weeks are going to be a whole new kind of hectic and I wont be able to do much to help but once things die down a little I can speak with Comp an do whats needed to send mine in. Its been sitting here in my closet the whole time so im a little peeved, I could have sent it in anytime I wanted
Old 04-04-2011, 08:43 AM
  #114
mike13's Avatar
I have a .68a/r for a tc76 that I can send in today, I haven't paid attention to this thread, if I let them use my housing do a get a free one?
Old 04-04-2011, 09:50 AM
  #115
rotary1307cc's Avatar
yeah sorry, i sold the tc78 becasue i had just enough room to squeeze a 78gts in to fit
never realized i never posted in here, sorry
there was an honest huge gain going to the GTS, and spool was similar, FWIW
Old 04-04-2011, 11:38 AM
  #116
JAX04's Avatar
how much longer is it? and how much larger is the compressor housing?
Old 04-04-2011, 05:12 PM
  #117
Im not faulting you for for it, honestly its really no big deal, I just wish I had known lol.
Old 04-04-2011, 08:24 PM
  #118
na it is alright to fault me, really am sorry
ok
the bearing housing on both the TC and GTS are ~equal in size
as are the exhaust housings on both.... very very similar in size
overall length of the turbos are similar with the GTS being just slightly longer
DP and everything from the TC78 bolted right up to the GTS
The only real size difference is in the compressor cover diameter, I would say the GTS is around ~1.5" larger in diameter
here is the TC78, take note of the distance from the compressor cover to the waterpump snout
and here is the GTS.... I had to grind the compressor cover and the water pump snout the get it to fit, so between those two pics it should give a good idea. You have to realize the compressor is clocked differently so that ate some space up for the GTS too
and watch the vid, it gives a good idea of the differences in size of the compressor housings
http://www.youtube.com/user/rotary13.../2/1L7CY2il5n0
hope that helps guys
Old 04-04-2011, 08:32 PM
  #119
JAX04's Avatar
wow, i seriously dont think i could fit that thing, i mean, with some cutting and ****, i probably could, lol
Old 04-04-2011, 08:34 PM
  #120
and for spool watch this vid, you can see how easily it lights up even with a tight converter
http://www.youtube.com/user/rotary13.../1/q_7bD8ORT_w
and so you know i have ridden in a auto 6.0 with a BW s475 and that thing was LAG CITY
for responsiveness/lag with 1 being fast and slow being 10
tc78= 1
gts78= 3
s475= 10
Quick Reply: Update on group buy of larger exhaust housing for tc78
