E85 Who has done it?
Old Jan 3, 2011 | 04:50 AM
427_LSX's Avatar
E85 is jiggawatt juice. I love the stuff.
I use it in all of my cars other than all out drag/dyno.
Example: (88mm, 408ci) we went from 803rwhp to 891rwhp with nothing else other than a complete re-tune.
Due to the swap we could run a couple psi more and still be on a safer tune than with our 98 octane (your 93) and that car gets driven around 900km (550 mile) a week
Its cheap, you get huge power gains, cooler temps plus its good for the the globe
Old Jan 3, 2011 | 07:44 PM
98Z28CobraKiller's Avatar
Restricted User
Originally Posted by T-Bones Goat
I'm not sure which injectors I'm going to use yet. I already have an AEM impedance converter in place and have been using 96lb injectors which were at their limit. I ordered a set of 125's before I decided to go E85 so now I am backing up.
I got a buddy with a brand new set of Bosch 150's low imp (same ones that I run) for $450. Send me a PM if you are interested.
Old Jan 3, 2011 | 07:49 PM
Restricted User
We've run a bunch of 7.9's @ 180+ MPH in LS2Formula's car on the "jiggajuice." LOL. It's a 3450# full interior legit street car. We are working out some bugs right now as we switched the engine management system but I hope to see a 7.70 pass before the end of the winter (our race season down here in Hell).
Old Jan 4, 2011 | 01:26 PM
Louis at GSS's Avatar
That is exactly the sort of info I was looking for. Any more results or info is greatly appreciated.
The Supra community has been running it for quite some time. Here are some Dos and Donts with it-
DO oversize your injectors. I like the ID2000s. PM for a good price. If Nick is tuning it, he will love you. He and I have known each other for 6/7 years now, so feel free to use what I have learned so far to reduce your learning curve.
DO run a big feed line. I always oversize atleast one size up. Its never hurt. Its always hurt when I run into pressure drop or improper line sizing because I went too small.
DO run a BIG stainless fuel filter. 25micron or smaller. I like the Monster Mesh from Kinsler.
DO test your E85. It takes a 125$ tester to test it and an ohm meter. Ive heard of less than E70 at some pumps, but have tested personally, E70-E86 at the local pumps here in dallas all across the last 6 months. It just recently changed end of november to a winterish blend.
E85 starts out life at E100. Naturally, with no liquor license, it gets cut with crap to E98.
From there, you can purchase E98, and cut it yourself with your own 93, or 100 octane to achieve your E85, or what ever Ethanol content you wish.
E85 at the pump is cut with what ever, 87, drippings, refinery trash, what ever they pick.
Having said that, in a typical spark iginition engine, E70-E85 have virtually the same Antiknock qualities between them, with in 2%
It accepts the same timing as C16. You will usually melt parts before it knocks. Thats been my findings.
Other than that, use good Ethanol rated stuff, hard anodized aluminum, and stainless in your fuel system parts, and go to town!
Louis
Old Jan 4, 2011 | 02:43 PM
Mr.Big's Avatar
^^^ good write up Louis!!! what brand tester do you recommend? I'd like to purchase one, I have a nice Fluke meter, but I would need to buy the tester...
Old Jan 4, 2011 | 02:57 PM
Kent-Moore J-44175, its a fuel composition tester. New around 500ish$? Used anywhere from 100-250. Shoot for a newer one, as there are some wear items if it was used a lot.
I test at the pump, takes about a minute, and a few goofy looks
The Kroger in Sachse and the Kroger on frankford/midway both are currently E73-E76 as of a week or so ago The pumps in Orlando for War of Imports were true E85
Old Jan 4, 2011 | 06:43 PM
Restricted User
We use a tester that's just a little test tube with some lines on it. You fill to one line with water and the other line with e85. The ethanol mixes with the water and the gasoline floats to the top. The lines tell you the percentage.
Looks like this. It looks like this one.
I think it was cheap. Like under $50 bucks.
Old Jan 6, 2011 | 08:48 PM
cjg454ss's Avatar
i think ive seen your car at shady side.
E85 is working great for me so far. It takes 30-40% more fuel which is tough with an electric pump. i ran out of fuel at 850ish rwhp with a 4303 magnafuel.
i just checked my BS3 log, with 160lb injectors i am at 76% duty on E85 with a base fuel pressure of 50lbs. that at 14psi of so. 800rwhp.
not knowing much about your car make sure your fuel system is alky compatable. any filter with paper in it will gum up. it happend to me, mesh screen filters are the ones that work best. Easiest way to tune is assuming your gas tune is good. add 30% to you VE. thats what i did in Big stuff 3. then tune it to 11.0 a/f, i know my car seemed to make more power in the 10s a/f. some say its to rich. its up to you, a dyno will tell you where it is best.
Old Jan 6, 2011 | 11:24 PM
T-Bones Goat's Avatar
Louis
Nick is the only one that will ever tune my car. That said I'm sure he would love those injectors but my bank account wouldn't. I already have the impedence converter in place so I will be trying to stay with a low impedence injector. Thank you for all of the other tips. I have been talking to Lonnie at Lonnie Performance and we have some plans for the fuel system. I will keep all of your tips in mind as we upgrade. Your experience is much appreciated.
Thanks for the numbers. I have been to Shadyside several times and will go back there in the next season. Hope to see ya there!
Old Jan 7, 2011 | 06:57 AM
cjg454ss's Avatar
also let me know how that alky injection does with no intercooler. I wanted to go that route but couldnt find anyone that had done it. i also have a 3 nozzle AIS alky kit but i havent turned the boost up yet.
Old Jan 7, 2011 | 08:40 AM
NicD's Avatar
7 Second Club
When you made 850 rwhp and ran that 4303 out what transmission was in your vehicle? I am pretty sure I am getting near where my 4303 is going to run out of pressure but haven't seen it dip yet at WOT. What did you step up to next as I can't seem to find a pump that is bigger that is street friendly at all?
Old Jan 7, 2011 | 09:04 AM
  #32
cjg454ss's Avatar
it was a th400 with a loose converter. my buddies car did the same thing. mid 800rwhp with a th400 and 9inch of 12 bolt. with a 6 speed it would be 1000-1050 rwhp.
the 4303 is the largest magnafuel for street use. i bought another 4301 to run in parrallel but decided not to use it. i figured you need 2.8-3.0 gal/min for 1100-1200rwhp on E85 through a th400. the 4303 pumps out 2.5 gals/min. i added the alky kit which is 0.5 gals per min. to get me to 3g/min. my buddy ran a big magnafuel pump that is 3.1 gal/min and had good fuel pressure. You could also run a boost a pump. i might do that to mine in the future. a guy did on yellow bullet and it increase about 200hp worth of fuel.
hope this helps
Chris
Old Jan 7, 2011 | 09:11 AM
  #33
NicD's Avatar
7 Second Club
hope this helps
Chris
Perfect, that was going to be my next question was how loose was the converter. It looks like I still have a bit of headroom then as I kind of go off of the same calculation that you use with a single 4303 at it's nominal flow rate would be around 1000 rwhp with a manual trans. The bigger magnafuel pumps seem to put quite a bit more heat into the fuel and they don't recommend them for much street use. I certainly wouldn't be opposed to using a KB Boost a pump on this thing if I need to just because it's one device I haven't seen fail yet so I consider it to be pretty damn reliable unit and it's not like it would be spiking the voltage all the time so I wouldn't think of much additional wear to the pump at all.
Thanks that definitely helped!
Old Jan 7, 2011 | 10:14 AM
  #34
I agree on the boostapump. They get a REALLY bad rep due to being used on stock wiring, and stock pumps, but when wired correctly with good wire, they really help.
We use two bosch 044s, and they are right at the limit at 1100 rwhp. Enough to push a 3300 pound car to 160 in 1500 DA. I added some larger wiring, changed up the feed line a little bit in hopes to extend the pumps further. If that doesnt work, I will add a boost-a-pump. Its still a street car, we dont want to run a Dial-a-flow and a weldon, so twin intank pumps is where we want.
I forgot about the fuel filter- Stainless mesh is the only way. Paper will gum up for sure.
Louis
Old Jan 7, 2011 | 11:58 AM
  #35
cjg454ss's Avatar
Louis
wow thats good to know, two bosch 044 will out flow a magnafuel 4303. the 4303 is 500+ bucks to.
Old Jan 7, 2011 | 04:01 PM
  #36
86MonteSS's Avatar
i'm in the middle of an E85 swap. 6.0, twin 6265's, ID2000 injectors
Old Jan 7, 2011 | 04:48 PM
  #37
71 chevy's Avatar
Im running a new efi system with no previous tunes, and a bad crank sensor.
I saw things on the dyno that would have caused any gas engine to disentagrate instantly.with e85, the engine held up fine.
Old Jan 7, 2011 | 04:50 PM
  #38
71 chevy's Avatar
We make 1020 on c16, and 1015 on E85. E70-e85 have almost the same antiknock qualities. We went 160 on pump e85, and it tested at e76.
I'll post more when I get to a computer, but I would do it. It'll pay for itself In a few tanks!
would it be a bad idea to cut the e85 with some more 93 gas if one is reaching the limits of a fuel pump or injectors? ie, get it to something like e70?
Old Jan 7, 2011 | 05:02 PM
  #39
LS1NOVA's Avatar
Is a BAP ok on a Magnafuel pump? Ive only really seen it on stock types, Walbros, etc.
Old Jan 7, 2011 | 05:31 PM
  #40
t-1's Avatar
t-1
I ve been running e 85 in my Trans Am for 6 months. I ran a mix in my 01 zo6 and my brother ran it for ten thousand miles in 600 whp talon. Its the only way to go if you have regular access to it. Couple things to consider 1. oil changes need to be more frequent or you need to step up brad penn oil or joe gibbs hot rod oil 2. its in the 23-25 percent range for more fuel. I am personally running 165lbs injectors, a weldon pump, 60 psi fuel pressure and was making 1004 sae whp. no knock, on 10 -1 compression albeit at high elevation. 3. I would still run an intercooler for consistency and safety, but with e 85 you dont have to run some huge or expensive intercooler. 4. I would use the highest volume gas station so you can to insure fresh clean fuel. 5. it will start in the cold(done it under 20 degrees out) but it can be a little rough. On the flip side it cranks long enough to build up oil pressure before fireing which is a positive to me when its cold out.6. Gas mileage does suck lol but spool is better.
