Lean problem....Help
Old Jan 13, 2011 | 11:25 PM
505OUTLAWZWS6's Avatar
Default Lean problem....Help
I have a 2002 turbo ws6 on e-85. Well i was driving home tonight from our local car meet and my a/f on the highway goes max lean on my aem wide band. So i decided to do a little testing and the car has way less power and is very slow to come up on boost. I brought it up to 2-5lbs and the a/f came down to 13.x. I immediately got out of it. Sounds like a fuel issue to me but i pulled one relay at a time from my 2 fuel pumps after bleeding the system down and they both immediately shoot to 43psi on my regulator. Could it be a fuel filter. It is a micron aeromotive filter on a -10 feed. Any other suggestions... I have been running it on 10psi all day. It is normally on 15psi.
Old Jan 14, 2011 | 12:39 AM
rotary1307cc's Avatar
in your scanner/logger are the injection times or inj. duty cycle similar to what they have always been normally?
Old Jan 14, 2011 | 06:39 AM
I will have to hook it up and see, what would cause that, tps or map sensor?
