spark plugs for a tt ls1
so 7psi, factory motor, what is the best?
im from New Zealand if that means anything... haha
any help is apreciated.
Not sure why, but the tapered seat seem to be very common in the US. Here in the UK, virtually nothing uses them
I tried both types in my Trickflow heads and some stock heads. Tip projection was exactly the same with either tapered or plugs with a sealing washer.
Obviously there are exceptions if you get a plug with a non standard thread length etc, but obviously that will be different.
Most normal plugs will fir just fine.
If plugs are awkward to access, consider some Platinum types. Ive used NGK PFR7B before ( normally used in Subarus etc )
projection into the chamber is the same with all plugs of similar heat range/design.
