Procharger owners : Poor Man's Beltwrap mod standoffs
#63
I'm guessing you missed the formulas posted in that link.
For 2.5 idler: Belt Length = 1.8897 * (SC pulley diameter) + 34.579
For 3.0 idler: Belt Length = 1.9248 * (SC pulley diameter) + 34.739
So for a 4.5" SC pulley with 7.65" crank, 2.5" tensioner and 2.5" idler, you'd need something around 43.08" belt.
For a 4.5" SC pulley with 7.65" crank, 2.5" tensioner and 3.0" idler, you'd need something around 43.40" belt.
So you need something around Gates K080433, Gates K080435, or Goodyear 4080435
#64
8 sec potential, 12 sec slip
Thanks Blake
Now I'm confused, because the Gates website says that the 38041 is 30.5mm wide..
Their website also shows that 38006 is 30.5mm as well..
Also, the 38006 shows its about half the weight of the 38041 for some reason.. They both have the same dimensions, and they are both made of steel.
#65
Just went thru the Gates website, and found all these candidates that would probably work:
P/N----OD----Width
36091...74.....39.25
36092...74.....46.25
36095...74.....33.0
36165...74.....57.0
36173...70.....33.0
36174...70.....33.0
36201...76.....38.0
36269...74.....42.7
(All are 17mm ID)
P/N----OD----Width
36095...74.....33.0
36165...74.....57.0
36173...70.....33.0
36174...70.....33.0
36201...76.....38.0
36269...74.....42.7
(All are 17mm ID)
