How would you turbo M6 guys like a boost by gear?
#68
it will not work on a 350Z using the wheel speed sensors, they are the active type
great product, too bad I dont have any wheel speed sensors. interested to see what type of output the vss has
#77
I just want to update and discuss my issues with you guys and hopefully yall can shoot me some suggestions.
Car: 2002 Corvette
First, I have the wheel speed sensor wire from the BBS box connected to the wires that connect directly to the RF wheel hub. It is throwing the C1233 CEL (RF wheel speed sensor circuit open/shorted). Thinking about adding some diodes to see if it will cure the issue.
Secondly (and most importantly), When I have the only 2 wires that connect the BBS box to the Eboost2 (orange and green wires), it cause my eboost2 to NOT display any vac/boost readings, but the controller still has power and the arrows are lit up. If I cut the connection, the eboost2 works normally.
I need ideas people
Car: 2002 Corvette
I need ideas people
#78
Car: 2002 Corvette
I need ideas people
Car: 2002 Corvette
I need ideas people
#79
Now that its in production what are the requirements to run this? I have an Eboost2 on my LSx Nissan 350z and would really like to run this. I deleted the email I got from one of your techs about getting it to run off the transmission speed sensor. Maybe I can call and chat with you about this...This would be a great way for us "swapped" guys to run this unit.
