Fast intake and Forced Induction
Old Feb 11, 2004 | 12:15 PM
Jammer's Avatar
Default Fast intake and Forced Induction
With a twin turbo set up, will the system gain or benefit as much from a better flowing intake as a N/A or Nitrous system might gain.??? Any input?
Old Feb 11, 2004 | 01:33 PM
mike m's Avatar
jammer i was going to ask the same question about my vortech though. I saw an lsx 90 mm intake on Jay(absolutes) flow bench yesterday. it flowed 12 cfm higher then a stock ls6. made me start thinking about buying one. I believe you would see more of a gain on a turbo car then a forced induction, considering the supercharger forces air into the intake already.
Old Feb 11, 2004 | 01:39 PM
HUGGER ORANGE SS's Avatar
IMO It's not woth paying that amount of money for a little more flow. I have the Weiand intake and ported to match the heads. It flow more than the LS6 intake now and I only paid 400 bucks, plus a little more for the porting.. Pict are in my Sig.. Also people say the heat plays a role on these aluminum intakes. I run my car hard and the intake is not that hot at all.
Clint
Old Feb 11, 2004 | 01:41 PM
y2khawk's Avatar
Any gain in system efficiency is gonna help, even with boost. Whether you get more flow for a constant boost level (ie keeping the same waste gate setting), or just a reduction in temps due less work from the blower, or, or...
Is it really worth it for nearly $800, or whatever the 90mm versions are going for? IMO, not yet. My LS6 manifold and unported TB are still doing just fine
Old Feb 11, 2004 | 01:45 PM
quickWS6's Avatar
Why haven't you ported your TB during all your work on the car? Just wondering if you had a theory behind not doing it, or you just hadn't got around to it.
Old Feb 11, 2004 | 02:12 PM
y2khawk's Avatar
I personally did think it would be worth much. I'm not really making the blade bigger, so why bother. Plus, it's alow easier to blow through the TB than suck through it like an NA combo. Can't draw through the TB past supersonic, that's why restrictors work in the racing world. But you can continue to blow through, just with a small hit due to pressure drop.
my .02 on it
Old Feb 11, 2004 | 03:29 PM
mike m's Avatar
could less restriction, like adding a bigger TB and having more flow put less strain on a blower and possibly loose boost?
Old Feb 11, 2004 | 03:47 PM
y2khawk's Avatar
Less intake restriction or exhaust restriction post blower will usually result in a lower measured manifold pressure. That does not mean there is less power or air being put into the motor.
Lower delta pressure across the compressor may result in less power being used by the blower, i'm not sure. But using the general connection between how a centrifugal blower map looks compared to a turbo map, you stay at the same flow but with less pressure ratio. Usually you end up moving to a more efficient range on the map in that case. And that ends up adding less heat to the air as it's compressed.
If you pulley up to get the boost back, you end up w/ more air(ie power)
In the case of a turbo, you usually maintain a constant pressure via the waste gate anyway so you get the added power without having to buy pulleys
When i say delta pressure, i mean the absolute pressure at the inlet to the compressor versus the absolute pressure at the outlet of the compressor.
Old Feb 11, 2004 | 04:25 PM
mike m's Avatar
thanks for the answer. I am probably at max impeller speed. so i wouldnt be able to gain any of the pressure back right?
Old Feb 11, 2004 | 04:36 PM
y2khawk's Avatar
Nope, if your maxing the blower openning up the intake system won't get you much.
I did the same thing w/ my Incons. Just not enough flow availible.
Old Feb 11, 2004 | 06:38 PM
Jammer's Avatar
Hawk, I didnt see you comment before so I'll ask here. Mu intake plumbing from turbo to intercooler is 2"...and 3" from IC to TB... should I be upgrading or see how it goes?
My DP's are stepped to 3" (each) at the waste gate exhaust BTW.
