PVC solution for Boosted Motors
The Original setup:
The New setup
Note: Those of you with the OEM pop up headlights will need to find another location for the Catch can. There is a well vented area just in front of the driver’s side firewall that would work with about 2 additional feet of PCV tubing.
If you had tubes running from each bank to a puke tank is that fine? Assuming this is a car not driven everyday..
Or would open breathers in the valve covers be fine...assuming you don't care about the fumes.
Just wondering what a good solution is as it seems like I have read about a 1000 different setups and someone has negatives to state about all of them.
I posted this on the CF as well and there's a large concern that even with the elite engineering catch can (stainless steel style condenser filter) that there's enough oil vapor getting through to the intercooler fins to present an efficiency issue with the intercooler.
Does this sound like a significant issue or is the catch can doing a good enough job?
Run a one way check valve in place of the PCV valve between an LS6 valley cover or front port on the passenger valve cover and the port on the side of the intake manifold.
Rear port of passenger valve cover has a hose going to the induction between air filter and turbo inlet.
Drivers valve cover port has a hose going to the induction between air filter and turbo inlet.
EDIT- wrote that wrong, revised.
Thats my .2 in this thread but its my understanding.
Ive seen in person 1000+hp f bodys with a vented catch can's using one way check valves in the vacume source. it works.
Note: his car is a 383 ls1 with a tc78 an runs the **** out of it
there are several plusses to a pcv system, hence why every major auto manufacturer invests in including them on their cars.
Key is when that flapper opens it needs to open large enough that the velocity is kept at minimum.
LS6 valley port to oneway check valve to PCV valve to catchcan to intake port...gives PCV at idle and around town and no oil in intake manifold with the can.
Pass side valve cover port and Driver side valve cover port to connector between airfilter and turbo.
Open cone filter on the Oil cap.
"MacGyver assists his old college buddy Jeff Stone in testing a racecar with an environmentally-friendly all-plastic engine. The Phoenix Foundation invested in the project, and Mac reports to Pete Thornton that the engine is performing even better than expected. "
