Methanol + Vertical Radiator Mod
For those of you who have gone through with the stand up mod on your radiator, if you were running a methanol tank up front (windshield washer fluid tank) what did you do?
It looks like once you stand up the radiator that tank has to be removed. I know there is a tank you can run from your trunk, but that seems sketchy. If anyone has any pictures of their setup, that would be helpful. Thanks!
That looks like a really nice piece! I agree w/ the fuse blocks though. I'm wondering if there is anything out there that goes where the battery is? I have no issue relocating it.
We can actually reverse the tank to the opposite side where the battery used to be. Basically would flip the top to where the notch is on the opposite side. We just built this particular tank for the driver's side since we're not running a stock fuse box on this particular car.
I have mine mounted in the rear and love it. Its a 3 gallon plastic fuel cell looks great and accents the car and methanol pump since both are black and red. Its mounted right behind the rear seats on the hump. Ill post pics when I get my car back
