AES Block Coming Soon!!
Old Feb 1, 2011 | 08:07 PM
Tirefire's Avatar
Default AES Block Coming Soon!!
Well I just pulled the trigger on an AES 390 block, nice FI cam and some Trick Flow as cast heads. My comppression looks like it will be around 9:6:1. Hoping to get some good numbers (700 RWHP+) hopefully more. Does anyone have any experience with this set-up, I was originally thinking about going with a L92/317 head but I finally settled on this head. I hope I made the right decision since it's been almost 4 1/2 years with my stock block and 8 lbs of boost with no problems. Let me know what you guys think.
Old Feb 1, 2011 | 08:16 PM
JAX04's Avatar
that is all
Old Feb 1, 2011 | 08:17 PM
1CAMWNDR's Avatar
Good choice. You will need a new cam to go with the larger engine and better flowing heads. 700whp should be no problem at all.
Old Feb 1, 2011 | 08:57 PM
Tirefire's Avatar
Yea I did get one, I believe its somewhere close to the EPP cam specs.
Old Feb 1, 2011 | 09:51 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
Nice! I can forsee those 60's getting maxed out as well with the potential in that setup
Old Feb 2, 2011 | 09:01 AM
Tirefire's Avatar
What does everyone think of my head selection? I'm wondering if I should have gotten a head that would have dropped my compression a little more. The only octane we have out here is 91 so I'm stuck with either a thick deck or a head with bigger chambers to lower my compression. Don't get me wrong I like Trick Flow, but I'm wondering if I made the rigt decision? What does everyone think? Just a little nervous this is my first forged motor!
Old Feb 2, 2011 | 10:04 AM
LS1RedZ's Avatar
The Trickflows are a bad *** head. I think you made a good decision. You definitely have a bad *** shortblock coming for sure. You have the money for a meth kit? I would recommend getting some 80lb injectors too.
Old Feb 2, 2011 | 01:54 PM
Tirefire's Avatar
Yea I'm probably going to send 60's to some Fuel Injection Place they told they can bore them out to 80 lbs. its cheaper $200. It's better than getting 80 pounders for $400. I think they're a sponsor.
Old Feb 2, 2011 | 04:15 PM
FMX05's Avatar
I'm building the exact same thing. I received my 390 short block in early December. It's been sitting on my K-member with the heads on for over a month now. I've been working too much to get it all together. I should have it in and running by tomorrow but yours will probably see boost before mine. Once I get the engine going I still have to buy and install a rear end and new clutch before I even look at a turbo kit and fuel system.
Old Feb 3, 2011 | 03:41 PM
Tirefire's Avatar
Anyone else have any thoughts on this?
Old Feb 3, 2011 | 05:49 PM
gnx7's Avatar
Those are nice heads and definitely get the bigger injectors. Compression should be fine.
If you can get e85 in your area.... I would run that.... plus some 103lb injectors.
Old Feb 3, 2011 | 08:33 PM
SnIpEz's Avatar
Bummer for the last couple months I've seen your sig and thought the whistle was referring to a Procharger
Old Feb 3, 2011 | 10:59 PM
FMX05's Avatar
GT-88/BW HP-88/T6/Truck manifolds/6 speed until it blows up.
As of tonight it is in the car and running.
Old Feb 3, 2011 | 11:37 PM
AES Racing's Avatar
To me I'd rather be at 9.5:1 where your build is at, better low speed drive ability. More compression less boost, vs. low compression higher boost, I think both roads lead to the same power level, within reason.
Another factor, the camshaft in your build will result in lower cylinder pressure. Smaller cam will have higher cylinder pressure.
Fraser
Old Feb 4, 2011 | 01:23 AM
Tirefire's Avatar
Fraser[/QUOTE]
I here you Fraser I'm just a little excited!! I guess I'm over thinking on the build just want to make as much power as I can with my little D-1 and be safe! What do you think about the injectors Fraser?
Old Feb 4, 2011 | 01:24 AM
Tirefire's Avatar
Fraser
Old Feb 4, 2011 | 01:00 PM
AES Racing's Avatar
I've had a 6 speed Procharged Fbody car run up to 800rwhp with 60lbs hr injectors, it had twin walbro pumps. Able to raise base pressure and keep up fuel volume.
Old Feb 4, 2011 | 04:52 PM
Tirefire's Avatar
You guys still buried in snow or did you get a chance to head up to the shop today?
Old Feb 23, 2011 | 01:22 PM
Tirefire's Avatar
Called AES yesterday and spoke to Fraser, who advised that my block was being machined and should be ready to go next week. I'm also getting ready to pull the tranny and have it sent to a shop to upgrade the internals hopefully it will last for a while?? Anyway once everything is back together it will be taken to Dallas where it will be tuned by a guy named "Troy" he's a pretty reputable tuner from what I here.. I would put the shop's name but I don't think they're sponors here. Corvette guys have a lot to say about this guy so I hope all goes well..
Old Feb 23, 2011 | 03:39 PM
Phil99vette's Avatar
7 Second Club
With a motor nice you need a nice set of heads like the trick flows. You'll be ok, the trick flows are way better than 317s for a boosted motor.
