Which heads TFS 225 or AFR 230 or ????
My mods are in my sig but Im curently adding a D1sc procharger to my H/C/I built 347. Currently I have TFS 215 heads milled to 62cc which puts me roughly at 10.5-10.6 static compression. I'm running e85 with lonnies twin pump set up and 90 lb injectors and am set up to run 12 lbs of boost. My tuner said that everything should be safe with this set up. Of course I know I will want more later on so I'm trying to Plan out my next set of mods but unsure on what heads to go with. I want to upgrade to a F1A, 1 7/8 kooks, Fast 102/102, Custom pat g cam, and either the 70 cc TFS 225 heads or the new 72cc AFR 230 heads. What do you guys think? I'm kinda leaning toward the TFS 225's cause the 215s are absolute killers in my current set up.
