LS2Formula New Personal Best 7.87 @ 179 @ #3695 Raceweight
#83
#87
Cam is really small for a solid roller and I'm pretty sure that the Billet Wilson peaks around 7,000 RPM but seems to carry well. It does seem to run faster when he holds first out to 7900-8000 but in drive (2nd) we try to keep her under 8K. The 3.25 gear is VERY nice and comfortable on the street.
#88
7 Second Club
#93
Right now he is in the process of replacing the stock oil pan with the Moroso piece and relocating the filter. Stock oil pan does not like those G's.
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
#95
Here you go on page 2
https://ls1tech.com/forums/forced-in...ds-come-4.html
#96
Fantastic numbers! Congrats! I'm contemplating a twin turbo build myself and I was wonders what size primary's are on your headers? You might has said that somewhere so I'm sorry if I missed it. Again, great numbers and a great set-up.
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
#97
IIRC you and Shawn bumped heads a little about this awhile back. Shawn was stating that when you are running some sick numbers using alot of boost the Marcella intake helped distribute the cylinders a little more even than the Billet Wilson which helped tuning and in turn making you faster.
PM Josh @ KYTP, he built them. Can't remember. They are either 1.75" or 1.875".
#98
wonder about the egt just bought the holley dominator system myself and I want to install egt's but haven't found what is going to be the best action to take
what is the problem with the ones that you are running
soorry not trying jack the thread just wondering
#99
My understanding is that it has nothing to do with the Holley EMS. The EGT system itself is standalone and outputs to whichever EMS you happen to be using. It has to do with how the probes themselves operate. Maybe Steve will see and shed some light. I try to keep my part well compartmentalized.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
