Another Poor Mans Belt Wrap Method
Old Feb 14, 2011 | 06:48 AM
mean94lt1's Avatar
Default Another Poor Mans Belt Wrap Method
well after reading the thread about the better belt wrap for the poor man i did some research and was going to do the same thing but when i got the pullys i didnt like how close the belt was to the edge...(im sure it would have worked but i didnt like it)..
I went searching for another method. I have a d1 with a 8 rib setup but i have the 6 rib standoffs that i spaced out. So i got to thinking i know that timing belt idler pulleys are wider and the way most of them bolt to the block are spaced with alot of backspacing and i figured if i flipped it around and spaced it right i could get it to work.
So i did just that, But after i got it spaced right so that it wasnt rubbing the j bracket, the j bracket was on a hard angle so i went to work with my bandsaw and measured and cut the ammount off i needed to and got the bracket straight. Everything worked out here is a few pics of my setup its basically the same thing that chevychad did but i changed my idler to a timing idler and cut down the standoff ond spaced stuff with washers to make it work.....
i know this is a little hard to read but i figured id make a thread on mine i did take it out for a drive last night and no belt slip at all and i gained 1-1.5 psi
Attached Thumbnails Another Poor Mans Belt Wrap Method-phot.jpg   Another Poor Mans Belt Wrap Method-phot1.jpg   Another Poor Mans Belt Wrap Method-phot2.jpg   Another Poor Mans Belt Wrap Method-phot3.jpg   Another Poor Mans Belt Wrap Method-phot4.jpg
Old Feb 14, 2011 | 09:51 AM
dschmittie1's Avatar
looks good Corey
Old Feb 14, 2011 | 10:53 AM
Need_a_Camaro's Avatar
Looks good. How much room do you have for the tensioner adjustment? Looks to be awful close.
Old Feb 14, 2011 | 11:57 AM
mean94lt1's Avatar
yeah its close but there is still some adjustment there if i could find the goodyear belt i need it would have more room for adjustment cuase the belt is shorter but that is a green stripe gates belt very heavy duty so im hoping it doesnt stretch much and i have the belt very tight right now
Old Feb 14, 2011 | 11:59 AM
mean94lt1's Avatar
Originally Posted by dschmittie1
looks good Corey
thanks man
Old Feb 14, 2011 | 02:58 PM
flame's Avatar
part numbers and dimensions of spacers would be a lot of help if someone else were to want to do this
Old Feb 15, 2011 | 05:54 AM
mean94lt1's Avatar
the only part number there is is the pulley which is napa part number t42031...and of course the belt which is 25-080427.....the rest of it was kinda measure and cut because if you have a 8 rib stand off it might be different since i had 6 rib i dont remember the exact length i would have to get that tonight when i get home but i use 2 thick 3/8 washers and 3 thin ones....once you get the standoff cut its just a matter of spacing the pulley away from the j bracket enough so it dont rub
Old Feb 15, 2011 | 06:51 AM
What's the diameter of the pulley?
Old Feb 15, 2011 | 12:09 PM
mean94lt1's Avatar
2.596 i believe is the diameter
Old Feb 15, 2011 | 01:16 PM
Is the id on the bearing the same as ChevyChad's drawing? I'm having my standoff made tomorrow, I'm tired of waiting on Motovative.
Old Feb 16, 2011 | 06:08 AM
mean94lt1's Avatar
no its completely different you dont just machine down the standoff in this one you actually cut it down in lenght.... like the 8 rib is 2.75 long and the 6 rib is 2.5 long i cut mine down even more than the 6 rib i forgot to measure it last night but its supposed to be a little warmer tonight ill try to get a measurement on it tonight....i have attached a few pics of the pulley i used so you can get an idea on what im talking about
Attached Thumbnails Another Poor Mans Belt Wrap Method-386667.jpg   Another Poor Mans Belt Wrap Method-1127496.jpg
Old Feb 16, 2011 | 06:27 AM
Ahh, I think I see. The stand off just sits inside the pulley. The pulley is 64 bucks at my local Napa, not exactly cheap, but cheaper than Procharger's.
Old Feb 16, 2011 | 06:34 AM
mean94lt1's Avatar
no its not cheap but i didnt want a cheap pulley cause that means the bearing is cheap and the stress and speed these spin i wanted a good bearing
Old Feb 16, 2011 | 11:54 AM
Let me know when you get some measurements, I'm exploring other pulleys as well.
Old Feb 16, 2011 | 12:17 PM
1bad lad's Avatar
do yourself a favor a get a spring loaded belt tensioner installed
Old Feb 17, 2011 | 06:59 AM
9t8z28's Avatar
Most of us can't or don't want to spend $1K on a tensioner setup. This mod has been proven to work.
