TC78 + stock radiator location - doable?
Old Feb 14, 2011 | 04:34 PM
evo462's Avatar
Default TC78 + stock radiator location - doable?
My engine is currently out of the car and has been for two months. I am going to try welding up a turbo hot side that uses a C6 exhaust manifold to keep the A/C. My current non A/C truck mani kit places the turbo a little high and requires a vertical radiator (which I am not necessarily opposed to). Being that the engine has been out so long, its hard for me to gauge how much space there is between the crank pulley and radiator.
I had another kit at one time built around a Master Power T70 that keeps the radiator in the stock location. I sold the MPT70 several months ago and don't remember its size in relation to the TC78 I have (1.15 AR turbine housing). I know they're considered one of the more compact turbos...to a point. I was wondering if anyone had used a TC78 (or turbo of similar size) in a front mount while keeping the radiator in the stock location? Removing the puller fans may also free up a couple extra inches.
Doable? Too big? Placement required too low and oil drainage issues?
Thanks!
Old Feb 14, 2011 | 04:43 PM
Johnv's Avatar
Thanks!
The TC78 is actually physically smaller than a MP T70
Old Feb 14, 2011 | 04:46 PM
evo462's Avatar
Really? The TC78 seems larger to me but its been awhile. The turbine housing especially.
Old Feb 14, 2011 | 05:33 PM
Tally TransAm's Avatar
very doable.
Old Feb 14, 2011 | 06:08 PM
evo462's Avatar
Ah...that's encouraging. What A/R is your turbine housing? It looks like you did switch to pusher fans though?
Old Feb 14, 2011 | 06:29 PM
Sweet_SS's Avatar
...Still under construction, but you get the idea.
Pusher fan will have to be used.
Old Feb 14, 2011 | 06:39 PM
evo462's Avatar
What about AC condenser? (I guess the appropriate thread title should have been stock radiator location w/ AC)
Old Feb 14, 2011 | 07:13 PM
.96 housing. there is enough room for a larger on though.
pusher fans are a must
Old Feb 14, 2011 | 07:58 PM
dudeman's Avatar
i did it with my old car. i used a 1.15ar. get a good set of fans. i used a thin flex-a-lite dual fan. i think it was the FAL240. i mounted them the the condenser so it pushed air through the condensor and radiator. just make sure there is a good seal all the way around the fans including the top and bottom between the condensor and radiator or you will lose you airflow through the radiator.
Old Feb 14, 2011 | 08:37 PM
1badWS6's Avatar
Tally what piece is that over the radiator/condenser location?
Old Feb 14, 2011 | 08:42 PM
southpaw0314's Avatar
which fans are everyone using?
Old Feb 14, 2011 | 09:55 PM
lt1 radiator shroud
no condenser, **** ac haha
dual derale 12". works great
Old Feb 14, 2011 | 10:07 PM
dudeman's Avatar
Originally Posted by Tally TransAm
lt1 radiator shroud
i have one of those i need to get rid of.
i used flex-a-lite low profile dual pusher fans.
Old Feb 14, 2011 | 10:20 PM
evo462's Avatar
lt1 radiator shroud
Well....im not going to the hassle of fabbing up a new hot side to NOT keep my AC...heh.
Old Feb 15, 2011 | 05:35 PM
020NN20's Avatar
I have a pte78gts with a .96 housing...stock radiator, stock fans in the stock location.....all you have to do is put ur battery in the back.....
Old Feb 15, 2011 | 07:39 PM
evo462's Avatar
Pics?
Old Feb 16, 2011 | 07:52 PM
020NN20's Avatar
Shitty pic, and i'm making a radiator support, thats just a temp. but you get the idea
http://www.facebook.com/photo.php?fb...00000594368290
Old Feb 16, 2011 | 08:32 PM
kmracer's Avatar
^ im guessing we need to be your FB friend to see that.
Old Feb 16, 2011 | 08:47 PM
020NN20's Avatar
correct....Dennis Pegues....just message me and say from tech, and i'll approve it....if you wanna see it...i suck with posting pics on sites....
Old Feb 17, 2011 | 06:56 AM
01Z28Camaro's Avatar
I squeezed a Pt88 with 4 inch downpipe in with stock location radiator.
