cheap turbos?
Old Feb 20, 2011 | 07:46 PM
FL Junkie's Avatar
Default cheap turbos?
im in the process of choosing a turbo. ive seen a few people mention the cheaper gt45. are cheap turbos like this worth it?
im also looking at the masterpower t70
Old Feb 20, 2011 | 09:31 PM
1badWS6's Avatar
IMO I wouldn't cheap out on the turbo if anything. I've heard nothing but good things about the MPT70 and that's what I'm going to be running.
Old Feb 20, 2011 | 09:38 PM
Hwystar's Avatar
I considered that same turbo, but now I have a MPT 70 sitting in my bedroom, while I gather all of the other parts i need.
Old Feb 20, 2011 | 10:46 PM
turbo iroc's Avatar
I've actually heard good things about these eBay units. Two of these on a big block = 1000 rwhp. One drawback is that they are physically huge and weigh close to 40 lbs.
Old Feb 20, 2011 | 11:54 PM
flippincamaro's Avatar
We have used plenty of the gt45 ebay ones, An never had a problem with them, I think we have used about 5 so far on different setups, Have seen 18pounds on a couple with no problems, Just prime them right.
Old Feb 21, 2011 | 12:18 PM
FL Junkie's Avatar
interesting. any more input?
i could get 2 gt45's and run twin turbos. that would end up the price of one MPT70. but its no lag and plus if one was to go down, i still have the other running
Old Feb 21, 2011 | 01:15 PM
Adam86's Avatar
that's pretty impressive. I kinda figured they would fly apart.
Old Feb 22, 2011 | 10:10 AM
02_ramair_ta's Avatar
I might try this out on a cheap 5.3, and see how long the ebay snail last.. If I do, I will keep yall posted.
Old Feb 22, 2011 | 10:20 AM
m8w6r77's Avatar
Check out Aprils issue of hot rod magazine. They did a 5.3 with one of these turbos. 594hp. So they work just not sure for how Long they will work.
Old Feb 22, 2011 | 10:31 AM
FL Junkie's Avatar
would it make a difference if i did twin turbos with 2 of them? would these turbos be good for a twin setup?
Old Feb 22, 2011 | 11:54 AM
lsxmalibu's Avatar
I ran mine all summer, and took it off to sell and was still nice and tight. Was going to do a MPT70...but ended up buying another! Here is a link to the company that builds them....
and on my car....it weighs 35 lbs
Old Apr 29, 2011 | 05:45 AM
JoshuaGrooms83's Avatar
Im considering buying one of those cheap ebay turbos just to see but i also realy want one of those oiless turbos. but hey are really pricy. Im considering one of those T72s with a .84 AR. Im trying to put together a custom rear mount.
Old Apr 30, 2011 | 05:20 AM
if you are doing a rear mount do not use the ebay gt45 turbos, We use them a lot on different ls builds, We did one on a rear mount an couldnt build boost for ****, just a heads up i have pics aswell
Old Apr 30, 2011 | 01:05 PM
ttbestas's Avatar
Have you any exp running twin turbos from this seller. I see gt28, but I guess they are to small for stock ls3, any suggestions? Thanks
Old Apr 30, 2011 | 01:27 PM
what size are the GT45s? Im not looking for any crazy amount of boost but a good 5-7psi would be nice to make about 450-500ish HP. Trying to make more of a autobahn hauler, not a 1/4 mile drag queen. but a nice 12 sec run would be nice too
Ive actually went with a T70 ebay turbo with a .84 AR Turbine housing. Just getting a somthing to start with. oil system will be remote as well to keep running lines to a minimum.
Old Apr 30, 2011 | 05:17 PM
Hey grooms, I made about 2 #s in about a half mile run on 231, It sucked so i swapped out to a gt42 i believe was the size, The size of the gt45 ones we use, has a 4 inch inlet, 3 1/2 exhaust vband, t4 exhaust flange, 3 1/4 outlet, i think .96 exhaust cant remember the intake side off hand right this minute
Old Apr 30, 2011 | 06:14 PM
stock48's Avatar
9 Second Truck Club
Nice setup. Are those shorty headers or custom?
Old May 1, 2011 | 02:27 AM
they look like shorties, i did a similiar setup like that on my ls swapped 93 pace truck, Now running manifolds an a cross over
Old May 1, 2011 | 08:40 AM
lsxmalibu's Avatar
Edelbrock shorty headers from a 4th gen camaro
Old May 1, 2011 | 04:40 PM
lbm13186's Avatar
nothing cheap about turbo
