Boosted Build
Old Feb 21, 2011 | 12:03 PM
95LTXZ28's Avatar
Default Boosted Build
Ok guys Im trying to get a build list together for a boosted ls1 Im going to start building. Ive been readig the boosted threads on here trying to get most of my parts together but theres a few things I have questions about. So here is my list and tell me if I have anything i dont need or something I should add to the list, basically just critique it for me. My goal is 700whp+ as cheap as possible.
317 Truck heads
6.0 or C6 exhaust manis
Turbonetics TC76 or TC78
Tial 38mm wastegate
60 lb injectors (motron, siemens, etc) any brand suggestions??
Tial 50mm blow off valve
Twin walbro pumps
CX racing intercooler ( I had good luck with these on subbys)
GM MLS head gaskets for 6.0
ARP head and main studs
ARP rod bolts
LS6 oil pump
LS6 intake
Ported tb (suggestions to use ported stocker for ls6 or go with a NW's etc)??
TR224 cam
Please feel free to add to the list I want the build to go smoothly so your help will be greatly appreciated guys and gals, thanks alot!!
Old Feb 21, 2011 | 01:14 PM
Phil99vette's Avatar
7 Second Club
317 Truck heads
Tial 50mTial 38mm wastegate
60 lb injectors (motron, siemens,m blow off valve
Twin walbro pumps
ARP rod bolts
LS6 oil pump
LS6 intake
TR224 cam
Factory rods and pistons?
Old Feb 21, 2011 | 01:43 PM
95LTXZ28's Avatar
I was going to try and keep them factory maybe get a better set of rings for the pistons. I heard that is a common failure on boosted stock bottom end builds.
Old Feb 21, 2011 | 04:54 PM
95LTXZ28's Avatar
Bump for more feedbck
Old Feb 21, 2011 | 05:09 PM
blue00ZZleeper's Avatar
I would do a lot more homework. Those bottom ends have way more failure points then just rings....
Old Feb 21, 2011 | 05:52 PM
willizm's Avatar
Some seem to be fine with just arp rod bolts on a stock bottom end if he isn't pushing too much boost. Also depends on how healthy his block is and how he drives it I suppose.
OP, I'm selling some brand new arp rod bolts(pro 2000) and arp head studs if you are interested. Getting a forged engine package and the vendor is supplying these.
Old Feb 21, 2011 | 05:55 PM
JAX04's Avatar
I would say its the Ring lands more then the rings them selves, and thats part of the piston.
Best of luck OP
Old Feb 21, 2011 | 05:56 PM
95LTXZ28's Avatar
I plan it to be not crazy boost and it will be a street strip more street car. The whole engine has 50k on it and came from an older guys car who bought it to have a newer camaro, not to beat the *** off of it. My plan is to do what I can with a stock bottom end, if it blows I'll build something else.
Old Feb 21, 2011 | 05:59 PM
willizm's Avatar
OP, you can look at my current build(in sig). Very similar to yours, but I ended up getting a 44mm Tial WG. I also decided during the tear down to go forged instead of going 8lbs on the stock bottom end.
Old Feb 21, 2011 | 06:50 PM
95LTXZ28's Avatar
Ok so maybe a set of Ross or cp pistons are in order to cure the ring land problem.
Old Feb 21, 2011 | 07:18 PM
evo462's Avatar
Ring lands are only going to be an issue if you're getting pre detonation, correct?
Oh - just read you're shooting for 700+RWHP. You're gonna have to crank the boost up for that.
Old Feb 21, 2011 | 07:29 PM
95LTXZ28's Avatar
Ok thanks willizm, and thanks for the input so far guys, like I said this is just a list im compiling based on suggestions and input from threads on here. I would like to see 700 whp or close to that which will require some more boost. I have no issue with doing forged rods and pistons, im just being budget minded.
Old Feb 21, 2011 | 08:22 PM
willizm's Avatar
Yeah brother I was in the same boat. Planning on forging the bottom end next year and tryin to adhere to a budget. Once I has the engine bay stripped down it just seemed worth the extra money to pull the engine nag go forged. Plus it's piece of mind that it would hold up without that lingering doubt intge back of my mind.
Old Feb 22, 2011 | 05:46 AM
95LTXZ28's Avatar
Ok so I can do forged pistons and rods and stock crank?
Old Feb 22, 2011 | 06:54 AM
willizm's Avatar
As far as I understand the stock crank is pretty strong. I'm keeping the stock crank.
Old Feb 22, 2011 | 08:45 AM
95LTXZ28's Avatar
Ok cool then forged rods and pistons will be on my list to. I'll check the crank out when I tear it all down. Also what are you boosted guys doing to beef the valvetrain up?
Old Feb 22, 2011 | 07:29 PM
95LTXZ28's Avatar
Any body have ideas for valvetrain mods. I see a few guys in magazines using stock rockers modified by Harland sharp??
Old Feb 22, 2011 | 08:49 PM
willizm's Avatar
using stock rockers, but upgraded the needle bearings with the comp trunion upgrade. I think the lifters are fine, but I'll let someone else chime in on that. Also using the patriot gold spring kit in the 317 heads.
