Lsa crankshaft
Old Feb 26, 2011 | 09:33 PM
rickykline's Avatar
Default Lsa crankshaft
From my research it's a 3.62 forged steel crank shaft. Would it be a drop in on a ls2? For 485 bucks it's a hell of a budget crank. Anyone know if it's a 58x or if it's got the stock ls2 size snout ? What about flywheel bolt configuration?
Old Feb 26, 2011 | 09:43 PM
JAX04's Avatar
In For Details
Old Feb 26, 2011 | 09:45 PM
rickykline's Avatar
Lol I hope someone chimes in
Old Feb 26, 2011 | 10:01 PM
LS1LT1CAM's Avatar
I work at a gm dealer that is a gmpp dealer I will find out details on monday I do know that it is a 58 tooth crank don't know about forging
Old Feb 26, 2011 | 10:09 PM
rickykline's Avatar
The forged steel statement was on wikipedia. Will it take a ls2 balancer and flywheel? Anyone have one?
Old Feb 26, 2011 | 10:55 PM
Brief Encounter's Avatar
There is a different bolt pattern on the flange of the crank, IIRC LSA is 8 bolts and LS1,2,3,7 are 6 bolts.
Old Feb 28, 2011 | 07:21 PM
JAX04's Avatar
Find anything out??
Old Mar 1, 2011 | 12:26 AM
killernoodle's Avatar
Flywheel bolt pattern will be same as ZR1 8 bolt, therefore: good factory twin-disc option.
Old Mar 1, 2011 | 08:45 AM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
Nope!
ZR1 is unique with a 9 bolt crank flange.
LSA is unique with 8 bolt crank flange.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Mar 1, 2011 | 10:19 AM
N2OBaby's Avatar
Exclamation
What is wrong with the stock LS2,LQ4/9 3.622 inch crank?
Why is the LSA crank "Better"?
Old Mar 1, 2011 | 10:51 AM
JAX04's Avatar
I'm curious for the same reason as the op. Its a "forged steel" crankshaft. And for a hell of a price at that. For the stock cube or 370 guys etc. That seems like a helluva deal. Added protection at a fraction of the cost. If it'll work.
I'm def not educated on the different motors But is the lsa a dry sump setup? If not then it should be the same length as our cranks?????
Am I completley out of line here?
Old Mar 1, 2011 | 11:54 AM
Callies Performance's Avatar
Aside from the bolt pattern on the flange, the LSA is the same in terms of dimensions as a standard snout ls crank.
Old Mar 1, 2011 | 04:16 PM
Originally Posted by Speartech
Nope!
Oh, you're right! I was looking at pictures of what I thought was an LSA and the other an LS9 flywheel. Apparently they were both LSA parts lol.
Why would they make cranks with 2 different bolt patterns??
Old Mar 1, 2011 | 04:31 PM
JUICED1's Avatar
This isn't the answer but it clears some things up.
http://juicedmotorsports.com/techinf...hortblock.html
Old Mar 5, 2011 | 10:41 AM
gjohnsonws6's Avatar
to the top
Old Mar 5, 2011 | 11:25 AM
I wonder what alloy.And how long will it take before they raise the price.Any part numbers?
Old Mar 5, 2011 | 11:53 AM
12603616 614 at my local dealer,590 on parts direct.Still not sure on alloy wonder if it is 5140? still a good price. Look out compstar,here we come...finally what appears to be an affordable decent 3.622 crank.Yes I know it has an 8 bolt flange,but that seems to be the direction the general is headed and most of us would be upgrading the flywheel or flexplate anyways.
Old Mar 6, 2011 | 10:00 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
I'm sure someone would make a flexplate with that bolt pattern. Depending on the price of it though it may just be cheaper to buy a crank that will work with the pattern we're used to.
EDIT: Anyone have a price on the LS9 crank or part number?
Old Mar 6, 2011 | 10:06 PM
tripblackls1's Avatar
EDIT: Anyone have a price on the LS9 crank?
does gm not make a flexplate for the lsa? i know you have the option of getting a ctsv with auto? i dont see why you could not use a auto ctsv flexplate?
Old Mar 8, 2011 | 09:51 PM
OWN3D BY MY PROF!
That is a good point. There would be your 8 bolt flexplate. It is a stock one though, but again on the budget it may not be a bad option. I'd like to see some people track down these part numbers.
