Low compression forged ls2
Old Mar 2, 2011 | 04:20 PM
Frametwista's Avatar
Default Low compression forged ls2
I'm getting ready to forge my ls2 I want it to have low compression thinking 8:5:1 so I can run the most boost and make the most power I can using pump gas and a alky kit.What are your thoughts?I don't think because of the low c r it will be a dog out of boost if I want more power then ill get her into boost but I don't think it will be bad anyways I've owned two grand nationals which were low c r v6's and out of boost they were not bad to me so your thoughts
Old Mar 2, 2011 | 04:47 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
Any more details about the setup? Supercharger or turbo? What size? Goals?
Old Mar 2, 2011 | 05:12 PM
O sorry about that its a 98 ta al ls2 with Turbo cam and springs 4l60 kytp truck manifold kit tc78 my goals are about 900 rwhp when I change the Turbo to a gt91 and the transfer will be a powerglide.I want to run 880's or so street stop car if there's any other info u need just ask me
Old Mar 2, 2011 | 05:27 PM
westtexasbuff's Avatar
8.5:1 is too low in my opinion. You need at least 9.3:1 - 9.5:1 compression.
Old Mar 2, 2011 | 05:30 PM
Why is it too low?and too low to do what I'm trying?
Old Mar 2, 2011 | 05:32 PM
What can 9:3:1 or 9:5:1 do that 8:5:1 can't?
Old Mar 2, 2011 | 05:47 PM
barnat's Avatar
Track or street build?
If both ide go 9.5 to 1 like i did with my LS2 364 turbo set up!I put down 650 rwhp on a small 10psi setting for the street and can go to 20to 25 for the track with meth if i ever felt the need,which i dont lol . 8.5 to 1 is just way to low IMO. Turbos will be a dog to spool up with that low of a CR unless your planning on a VERY high stall convertor which ='s more heat to the tranny IMO
Old Mar 2, 2011 | 06:35 PM
I disagree grand national v6's are very low c r and I was spoiling a 70mm Turbo with only a 3800 stall I'm just trying to find a basis on why people think it will be such a dog speed Inc sells a boost block that's 8:5:1 comp and the made 995rwhp with it I think they know there stuff if its only making 350hp it will still spool the hell out of any Turbo smaller than a 98mm
Old Mar 2, 2011 | 06:40 PM
It will be a street strip car with a lot of strip time I'm really not concerned with instant boost if I was I would have a roots blower around town just driving a 8:5 comp ls2 off boost should still have enough grunt to pass people
Old Mar 3, 2011 | 03:22 AM
SnIpEz's Avatar
Too lazy and tired to get into it right now but I was also going to say the same thing, that CR is too low IMO. I would run it about a point higher to hit the sweet spot.
Old Mar 3, 2011 | 03:33 AM
lt1773's Avatar
too low better to stay between 9:2:1 to 9:5:1
Old Mar 3, 2011 | 05:13 AM
BigRich954RR's Avatar
way to low if your doing meth. I did 16 psi on 11.1 with cheap pump gas and meth
Old Mar 3, 2011 | 06:38 AM
GS Racing's Avatar
8.5 means you have the potential for big boost on pump gas without having the complication of meth etc. Which to me is a big bonus.
Personally I like much lower so can see 30psi on pump fuel with no AI. Boost = Torque. Not like thats ever lacking on a LS2...!
Ive ran as low as 7.2:1 before on engines as small as 1.4 litres, and in my eyes it doesnt make much difference to off-boost low rpm performance, not as much as a long duration cam or huge head ports does anyhow.
Old Mar 3, 2011 | 06:53 AM
tittan1500's Avatar
I would rater run 8.5 comp and avoid meth all together. relying on meth to keep your engine alive is just stupid
Old Mar 3, 2011 | 07:53 AM
GS Racing's Avatar
My last engine expired due to the AI failing halfway down the strip. 23psi on 9:1 and pump fuel. Wasnt happy with much more than 15 without it.
Old Mar 3, 2011 | 09:00 AM
TracyRR's Avatar
I run 8.7 comp. on my setup.... Off of boost, i think it has enough torque on the street. if i had to do it over, i would run another point of compression but that is only because i am greedy. Best of luck
Old Mar 3, 2011 | 09:30 AM
dschmittie1's Avatar
How much power and how fast are you looking to go. Setup with the procharger was 10.0/1 Ran well on pump and Meth. 13psi and went 9.8@141mph.
My new setup for the Turbo build I am doing will be more like 9.8/1 and plan on seeing 15 psi regularly. a properly setup meth system with the a car that is properly tuned so that IF you loose the Meth it pulls timing and saves the motor. I know MrBig or whatever his name is had a Meth failure doing a Mile pull and having it tuned properly pulling timing when it saw the IATs go up saved his motor
These cars like CR even on boost. And with a forged motor there is no reason to go as low as 8.5/1 If you want to stay lower on the CR the lowest I would go it 9.0/1 but 9.2-9.6 is what I would shoot for
Old Mar 3, 2011 | 05:45 PM
Nobody is giving me any basis on why its too low and wont work well like stated earlier in the post with low c r u have the potential to run night boost numbers on pump gas what do you mean it will be lazy when boost comes on it will hit like a freight train and the ally is just for a safeguard nobody is relying on it my low c r motor will do just as good as a higher c r motor until I hear a good reason y ill stick with it
Old Mar 3, 2011 | 05:49 PM
Sorry bout the spelling I'm on my Droid
Old Mar 3, 2011 | 05:55 PM
I stated earlier in the thread that it is street strip a lot of strip I don't care about street manners I want to run 8.80s
