347 for boost?
Old Mar 12, 2011 | 04:04 PM
02LS1ram's Avatar
Default 347 for boost?
I want to start collecting parts to build a 347 that will be Procharged. Im more then likely goin to run the stock crank, as far as rods and pistons im not to sure what to run. I'd like to hear some of u guys combos that are proven runners. Car is street driven and sees the track on the weekends every once in a while. As far as Compression im figuring and 9.5-1 area. Boost around 12psi.I want to run it on pump gas W/ meth injection. I would like to keep in somewhat budget minded. Thanks for everyones help
Old Mar 12, 2011 | 04:18 PM
yelo04goat's Avatar
pistons je or wiseco... i got wiseco -11cc dish they are sexy pieces.. (still building)
rods you will here lots of different things about the rods out there im goin to be running eagle rods.. some say they are not good some speak highly of them... compstar rods seem to be REALLY popular and are still fairly priced... FI isnt cheap.. but you can buy used parts and save some coin.. there are some good deals in the classifids
good luck man!
Old Mar 12, 2011 | 11:01 PM
02LS1ram's Avatar
Anyone else I know there's a ton of guys running 347's
Old Mar 13, 2011 | 12:24 AM
Adam86's Avatar
I'll be running Diamond -9.6cc dished pistons and Scat I-beam rods. Planning on 9.2-9.5:1 at 10-12psi.
Old Mar 13, 2011 | 12:33 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
I ran compstar rods and mahle pistons with my 347. I reused the rods and went with wiseco pistons on my 370.
Old Mar 13, 2011 | 06:51 AM
Packy's Avatar
I went with Diamond Pistons w/file fit rings, Lunati Rods, Comp lifters, Comp adj. Timing chain, ARP main studs, GM MLS head gaskets, reconditioned stock crankshaft, LS6 PCV valley cover/PCV set-up, and LS6 oil pump. My compression ratio is 9.6:1. It was built in 2003 and is still chugging along nicely. It has continued to get faster every year!
Old Mar 13, 2011 | 07:53 PM
02LS1ram's Avatar
I def want this motor to hold together im leaning toward compstar rods. For the price and quality you can't beat them. Pistons im goin to have to do some more research yet
Old Mar 13, 2011 | 08:26 PM
fatmat80's Avatar
I went with Weisco pistons, compstar rods and stock crank. So far so good. I was advised against eagle products as mentioned above. Because they were my first choice based on price.
Old Mar 13, 2011 | 10:22 PM
02LS1ram's Avatar
Which weisco's did you go with I've been looking at them as well. They look to have a pretty thick ring land. Haven't heard to much on eagle stuff. Also how high do all u guys rev (rpms) these things ?
Old Mar 14, 2011 | 06:54 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
We used Diamond pistons, Total Seal file to fit rings, and Compstar rods on quite a few builds back at the old shop with very good results. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Mar 14, 2011 | 07:10 AM
C5kid's Avatar
Diamond -8.66 cc pistons, K1 tech rods, stock crank. MikeP has the same setup as me, but w/ a 4" crank.
Oh, and mine is 10:1 comp and I have been runnign 13# of boost w/ no problem.
Old Mar 15, 2011 | 08:19 AM
02LS1ram's Avatar
Who makes K1 tech rods never heard of them. Yea I've seen
Some Videos of That car things a rocket ship.
Old Mar 15, 2011 | 08:30 AM
dschmittie1's Avatar
Mine when procharged was exatly like C5kids except I had callies rods.
Old Mar 15, 2011 | 08:35 AM
AutomagicLS1's Avatar
My budget 347 was a ls6 block, stock crank, used forged mahle -4cc flat tops and used scat h-beams, AFR 225 heads with LS9 gaskets. It made right about ~800 rwhp for atleast a hundred long pulls on the streets and it did at once make 1142 rwhp. We pulled the running motor out for my new AES 408. I thought the 347 spooled fairly with my GT-88 (which it did) for what it was but this 408...holy **** it works well with my GT-88
Old Mar 15, 2011 | 01:03 PM
AZZKIKR's Avatar
LS6 based 383
10.3:1
Weisco pistons -8cc
Callies compstar Rods
Callies Crank
Would have used the same brand of pistons and rods if I had left it a 347 and just used my stock crank.
Old Mar 15, 2011 | 01:38 PM
digitalsolo's Avatar
I have Wiseco 2618 forged/coated pistons and Callies Compstar rods. Stock crank.
Old Mar 16, 2011 | 09:30 AM
02LS1ram's Avatar
How big of a -cc dish should I go for the pistons? I'm running the brute speed/ epp blower cam If that helps
Old Mar 16, 2011 | 09:40 AM
What are the cc of the heads you are running. The diamond -8.6 cc and a 64cc 243 head puts you are 10.1
Old Mar 16, 2011 | 11:23 AM
02LS1ram's Avatar
I still have the stock 241's on the car right now. If my funds are looking good yet I might look at a set if AFR heads but as of now I'm sticking with the 241 heads.
Old Mar 16, 2011 | 12:07 PM
I would get the Diamond -8.6 cc piston. Should put you around 9.6ish
