AES 390 Ready to order turbos
Old Mar 16, 2011 | 02:47 AM
madmax4499's Avatar
Default AES 390 Ready to order turbos
I like the precision turbos. I have no idea what to get.
im looking to max out a 92 oct. pump gas tune for the street, If i could get 1000 hp on race fuel that is plenty for me.
AES 390
Mast CNC LS3 heads med. bore.
copper h/g with o-ring/receiver groves.
vic.Jr. 92mm t/b
AES turbo spec cam
stock ECM w/ HP tuner 3 bar SD tune.
80 lb FIC injectors? return regulator w/2 walbros?
truck manifolds
TH-400, Griner brake,
PTC converter. flash to 4500. 5500 on the brake?
Fab-9 3.55 gears 29-18.50-15 tires
items with a ? have not been ordered yet.
pt 6765 T-4 .81 X-2?
comments/suggestions?
Old Mar 16, 2011 | 06:08 AM
LS1PUNK's Avatar
Are u looking for room to grow with the turbos or trying to Max them out straight out of the box?
PT6265's are rated about 700 a peice while 6765's are rated 750 a piece.
Either way, both will have the ***** to get u what ur looking for.
Old Mar 16, 2011 | 10:34 AM
DrTurbo's Avatar
LS1TECH Sponsor
Those units will work. Also might want to look at the TC7065's or 7068's as well. Spool very similar and tons of power with them as well.
Old Mar 16, 2011 | 12:39 PM
madmax4499's Avatar
sure a little room to grow is good. Im thinking without a six bolt block, anything over 1000 rwhp is borrowed time. I dont want to have to worry about pushing water every time i push the car.
who makes/sells the TC7065's
Old Mar 16, 2011 | 01:13 PM
DrTurbo's Avatar
LS1TECH Sponsor
Turbonetics.
Old Mar 16, 2011 | 01:33 PM
madmax4499's Avatar
Feel free to PM me a quote. I have had several turbonetics in the past never a problem with them.
are they basically a hurricane based turbo? i dont see any information about them.
4" in 2.5" out? t-4 w/3" v-band? I am a Buyer, not a BS'er.
Old Mar 16, 2011 | 01:38 PM
Clean94Z's Avatar
or u could go billet 6765's are rated at 900 each.
Old Mar 16, 2011 | 01:51 PM
98Z28CobraKiller's Avatar
Restricted User
a couple of masterpower 70's would get you there easy for 1/2 the price tag.
Old Mar 16, 2011 | 09:42 PM
madmax4499's Avatar
thanks for the replies, shocking! I havent got a PM from a vendor?
Old Mar 17, 2011 | 10:31 AM
DrTurbo's Avatar
LS1TECH Sponsor
PM sent...
Old Mar 17, 2011 | 12:25 PM
madmax4499's Avatar
Got it, thank you. I sent one back.
Old Mar 18, 2011 | 06:24 AM
LS1PUNK's Avatar
Why run 2 6765's that are capable of almost 2k hp while the op is looking for 1000?
That $ could be spent else where.
Old Mar 18, 2011 | 09:58 AM
LS1NOVA's Avatar
More power at a lower boost level.
Old Mar 18, 2011 | 10:17 AM
madmax4499's Avatar
that is what i am hearing as well. a lot of well respected builders have recommended the pt6765's, I also like Dr. turbo tc70's as well, im sure everything mentioned here will get me there without issue. im ready to pay for them, now i just need to find someone willing to take my money.
Old Mar 18, 2011 | 11:24 AM
LS1NOVA's Avatar
Louis at GSS.
Old Mar 18, 2011 | 07:57 PM
madmax4499's Avatar
Louis, Did not answer his phone or call back But thanks. Im slowly working a deal with Dr turbo. Looks like monday i will be paying for someones turbos. Feel free to convince me what i need.
so far im looking at
TC-7065's third the price
PT-6765's not the 900hp each versions.
MP-70 half the price
any others i should consider?
PT-
Old Mar 18, 2011 | 08:58 PM
Firechikn's Avatar
Might want to ditch the 80lb inj for some in the 95lb range. Unless you plan to run alot of base pressure.
Old Mar 18, 2011 | 09:11 PM
madmax4499's Avatar
thanks, im not sure what to do with the fuel system. i do know two walbros with -8 feed -6 return, rails and a boost re. regulator will be fine for what im doing. the question is do i just give it straight 58 to 60 psi and let it eat. or run 43.5 and re. "boost only" at 1 to1. so at 15 psi i will have 58.5 psi. it will be an SD tune so the entire VE has to be tuned anyway. the way i understand it the 80 lb injectors are rated at 43.5 so at 58-60 psi they will be " 9?lb. i dont have the math in front of me. I wish there was a set in stone way to do it. way to many opinions in the search.
