SRP pistons for boost?
Old Mar 16, 2011 | 07:05 AM
green95vert's Avatar
Default SRP pistons for boost?
Hey guys, I wanted to make kind of a spinoff thread of ZGOBYBYs thread so I don't clutter hers up.
I have a set of SRP -31cc pistons in my car now, transmission is off getting faceplated/viper spec'd by RPM. Running 8.5:1cr, LE Trick Flow heads, LE custom cam (.570 224dur 114lsa), GT88 turbo, 17ish psi w/ 93oct and meth. Engine is on a stand right now, block looks damn near new so I'd just need to hone it and toss some JE's in. I'm thinking my head gasket would pop before a piston (FelPro 1074).
Would it be worth the $1200 to buy JEs, rings, and have my crank rebalanced or should I just keep with the SRPs?
Old Mar 16, 2011 | 10:13 AM
96TransAmboosted's Avatar
how do the srps look? why change if they worked out for you?
Old Mar 16, 2011 | 03:50 PM
Because the SRPs have a higher silicon content than JEs, makes em weaker. I see a few N2O guys hate em, and a few boost guys run 22-24 psi on em. They look great, don't want to regret not changing them later.
Old Mar 16, 2011 | 04:22 PM
87silverbullet's Avatar
I don't think you are putting enough boost on it to be worried. If you were hitting it with 25psi then I would say change them and get a set with a good compression height.
Look at it this way, there are guys running the boost you are on stock ls1 pistons and rings.
Old Mar 16, 2011 | 04:50 PM
1toofastlt1's Avatar
I have those pistons in my stroker with the hellfire rings. Haven't ran it yet though
Old Mar 16, 2011 | 06:43 PM
Jontall's Avatar
Stay away from 4032 alloy pistons... You want forged 2618 alloy pistons.
Old Mar 16, 2011 | 07:23 PM
Blackbirdws6's Avatar
I went with the JE's just because I wanted a little bit of a safety net if something goes a bit wrong for a moment. I'm sure with a good tune and reliable setup, the SRPs will hold up just fine at your boost level. If you get a bad tank of gas or the tune isn't spot on in a particular area, the SRPs may not take a beating like the JEs.
Just my $.02 on my choice.
Old Mar 17, 2011 | 06:29 AM
Jontall- They are 4032s :-(
Blackbird- A safety net is a good thing, your bottom end and mine are almost identical. What rings are you using in it?
Old Mar 17, 2011 | 09:31 AM
Jontall's Avatar
I know they're 4032 alloy, that's why I'm telling you to stay away from them. Get a set of Wiseco or Diamond pistons.
Old Mar 17, 2011 | 04:14 PM
if you sell the SRP ill buy them for my new project.
Old Mar 17, 2011 | 04:26 PM
BLSolutions's Avatar
I went with the total seal gapless top ring set.
Old Mar 17, 2011 | 05:48 PM
stock48's Avatar
9 Second Truck Club
I agree the 2618 is a stronger material and will tollerate more abuse but there is nothing wrong with a 4032 piston if things are set up right. Also all pistons are not created equal. A srp piston desinged for boost with a .250-.300" thick deck, and top ring down .300" is going to take alot more boost than a light weight flat top srp designed for NA.
Old Mar 17, 2011 | 06:46 PM
blackmagicturbo's Avatar
sounds like the op has already made up his mind on the 2618,,so would someone help him get the right pistons ?
Old Mar 18, 2011 | 08:21 AM
^Lol. I'm just trying to find a few reasons to shove me over the edge.
96TransAMBoosted- Sure, this'll MAKE me get JEs lol. They have 822.6 easy miles on em, hardly any wear. I can get some pics for ya sometime if you want. PM me if you wanna.
Old Mar 18, 2011 | 10:33 PM
I hear not to go gapless. Any reason you used them? I hear they give a great 2-3% leakdown after some hard miles.
