Comp turbo OILLESS TURBOS
#42
So what kind of pricing for the oil less 7271 with basic compressor wheels and like with. 1.00 a/r
For just 600-700rw for remote mount
I just got real interested
I hate e oil pumps and mechanical scavenge pumps cost more than the conventional turbo itself
I would def pay to run a reliable remote setup without a e oil pump
#45
Hmmm intersting two 70 mm up front on a vette 1000 HP +. I want to see these things punished befor i drop a dime. I email them with no response on how much heat they can handle. This wuld be a great solution to my dreams of a tt vette rearmoutn for front mount. I HATE PUMPS!!!!!
#47
well im waiting on repsonce for them, but might as well ask here as well, what would be a good oil-less version of a T70 with a more conservitive .84 or .91 ar? Im trying to do a rear mount turbo and if i could get one of these oil-less turbos that would be AMAZING!
THeres so many different kinds of turbos on there website i dont even know where to start. No need for one of those race billet ones for me, but does anyone know what would an oil-less would run equal to or better then a T70?
#48
what specific t70 are you looking to compare to? an old school T70 Q trim would get beaten handily by a 6768 comp turbo, while a 7068, 7071 would make a solid 100whp more. remember that a TC76-TC78 turbonetics would be compareable to a 7268 comp, so you can go from there.
I would suggest a CT43- 7071 with a 1.0 AR divided housing. That should spool similar to a old T70 pretty easy, and gives you the option to add a spool valve for full boost at 2500rpm in the future.
Just an example, I have a billet CT43-6768 ball bearing on a stock 2jz with a 1.0 A/r divided housing and a spool valve. In 4th gear i can floor it from idle and have 20psi before 3000rpm and it will make an easy 600+whp with very low backpressure
#50
I was under the impression that with rear turbo settings, anything over .84 A/R will lag pretty bad.
I was looking at this one for starters. what do you guys think?
CT4 Standard Compressors TRIPLEX CERAMIC™ Ball Bearings
CT4-6768/ P# - 114677
Dynamic (Compressor Seal)
HE 68 Turbine Wheel
800 HP capable
Aluminum with water ports (Bearing housing)
T4 with 3'' V-band
T4 undivided Tangential Open w/ .81
Compressor - 4” Inlet / 2.5” outlet / AR .70
Info directly pulled from website mind you.
Other key points
• Anti-surge compressor housing
• Interchangeable with 60-1 series turbo models
• Available with internal or external waste gates
• Lightweight high efficiency 10 bladed turbine wheel
• Available with water-cooled bearing housing
• Offered with dynamic or carbon seal
• Lightweight aluminum bearing housing
HE 68 Turbine Wheel
800 HP capable
T4 with 3'' V-band
Other key points
#52
I'm very interested in the oil less versions. I've had some people come to me to build em a remote setup. But after that last pump failure I'm reluctant to build another. Buy these oilless units change my mind.
If u do the math the oil less turbo costs less or comparable to conventional turbo with e oil pump and less headaches and chance of oil failur.
Fu(k the turbo, I'm worried about the engines bearings in case of oil pump failure.
#54
#59
HE 68 Turbine Wheel
800 HP capable
T4 with 3'' V-band
Other key points
HE 68 Turbine Wheel
800 HP capable
T4 with 3'' V-band
Other key points
