F/I or H/C
Old Mar 18, 2011 | 08:39 PM
bwilde86's Avatar
Default F/I or H/C
bought my car about two years ago. have lid LTs ORY magnaflow catback on the way monster stage 3 clutch and a rebuilt beefed up t56 transmission. Question is this: i want to do a power add mod next and cant decide between a procharger setup or heads and cam. procharger is "bolt on" and me and my friend can do it in my garage. the heads and cam will most likely need someone to do it for me as my experience is limited on cars. I am mechanically inclined but havent dug into an engine. What do you guys suggest? its a weekend only driver since i drive my work truck for work. Are prochargers still reliable or do they cause stuff to break on the motor. It will basically be a street car with time at the track rarely. any help would be appreciated as to which kit would be best. looking for around 500 rwhp hopefully. heads and cam i was thinking of was the afr 215cc heads and a matching cam with new rollers rockers etc.
Old Mar 18, 2011 | 09:26 PM
NemeSS's Avatar
Or sell ur as is running ls1 and apply funds to 6.0 iron block build with good heads and cam. The forced induction route has lot of lil hidden costs that will add up
Depends on ur budget and skill.
Old Mar 18, 2011 | 09:28 PM
Photochop's Avatar
It will be easier to make 500+ going FI, but harder on your wallet. What years the car? If <'00 you'll wanna put a set of arp rod bolts in it, they're notorious for letting go and causing big probs over 5800rpm.
Old Mar 18, 2011 | 09:33 PM
bwilde86's Avatar
I have a 2002 ws6 m6. Heads cam route was going to be 4500-6000 dollars. Figured spend a little more for a procharger that I can install myself
Old Mar 19, 2011 | 12:46 AM
bwilde86's Avatar
Since im such a novice am I getting over my head with f/I?
Old Mar 19, 2011 | 03:25 AM
fatmat80's Avatar
I would not say that. They are easy to install. But boost is addicting and on a stock motor your more than likely headed for an overdose.. however procharger ftmfw!
Old Mar 19, 2011 | 07:50 AM
nodrok's Avatar
FI easier to make 500hp. and cheaper. You wont make 500hp NA cheap with a 347 ls1. Im sure bob at brutespeed has a turn key package for 500hp. Good luck.
bwilde86's Avatar
What is a good kit to start with?
Old Mar 19, 2011 | 08:02 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
http://shop.brutespeed.com/ATI-1GJ20...-Speed-Kit.htm
The above D-1SC kit is a great way to go, as it will allow further upgrades to your engine down the road without becoming obsolete.
Thanks! Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Mar 19, 2011 | 09:49 AM
yessir's Avatar
both!!!!!!!
Old Mar 19, 2011 | 12:16 PM
Avengeance's Avatar
Originally Posted by yessir
both!!!!!!!
What this guy said!
Even if its a small blower cam and 317s.
Old Mar 19, 2011 | 12:37 PM
bwilde86's Avatar
Well im just doing a project a year. Don't have 12k to drop in it all at once. So figured I could do h/c or save money for the procharger. Eventually I would like to do both obviously.
Old Mar 19, 2011 | 12:42 PM
bwilde86's Avatar
That's a nice kit from brute speed. Is it a complete kit or will I need other pieces to make it work? Sorry for a the noon questions.
Old Mar 19, 2011 | 01:17 PM
tripblackls1's Avatar
go for the FI
when i first bought my car 4 years ago i originally wanted to go boosted but then was talked out of it, and over the years my car has had almost every performance mod done to it
bolt ons then bolt ons + n20 then cam +n20 then h/c/i then h/c/i +n20
overall my car has gone very fast but ive never really been satisfied and now im almost done with my boost build but i would have saved a ton of money if i went boost first !!
Old Mar 19, 2011 | 02:24 PM
nodrok's Avatar
Bob what kind of #'s are stock ls1's laying down with your kit?
What kind of power ia that kit capable of?
Old Mar 19, 2011 | 03:51 PM
bwilde86's Avatar
I would like to know this as well
Old Mar 19, 2011 | 03:58 PM
bwilde86's Avatar
Old Mar 19, 2011 | 08:30 PM
nodrok's Avatar
send Bob a PM in case he dose not check back in.
