Low Oil Pressure
Old Mar 18, 2011 | 10:49 PM
GMouldy's Avatar
Default Low Oil Pressure
Whats up guys,
Had a quick question about guys with rear mount turbo's.
Is anyone experiencing low oil pressure at the gauge? When i first start it up its about 40 lbs. after she warms up the pressure is not as high but no where near 40lbs. even a few times last summer when i did get to take it out and i was sitting at a light, it would dip down to nothing and the Check gauges light would come on. I freaked me out so i turned the car off and trailered her home. After i got it home i went to show my father and it did the same thing. had fine oil pressure have it was cold and once it warmed up it started to fall.
Now the pressure does climb when the rpms go up, and the motor has never gotten hot or came close to getting hot.
So I've been racking my brain about this, and the only thing i could maybe think of was that the motor is experiencing a lack of pressure due to pumping oil to the rear of the car to the turbo and to the scavenge pump.
I'm half scared to drive the car now, i've also thought about capping the oil line to the turbo just to see if the gauge is messed up but i don't wanna cut off the oil supply to the turbo.
Can anyone help me out here?
Old Mar 18, 2011 | 11:06 PM
LaBLKv6Z's Avatar
Could possibly be the sensor behind the intake. I gained about 15-20 psi after I installed a new one lol (broke the original sensor trying to use a regular deep socket).
Old Mar 20, 2011 | 02:29 AM
WHPLASH's Avatar
What does it get down to? I start at 40 and go down to 20 warmed up with a 9:1 compression block.
Someone correct me if I'm wrong, but compression plays into that. ???
Old Mar 20, 2011 | 11:43 AM
STAR's Avatar
GMouldy, what weight oil are you using?
Compression has nothing to do with oil pressure. Your engine clearances such as main and rod bearings will determine your pressure. Stock ls motors have tight clearances that result in high pressures vs a built motor that may be built with "looser" clearances for more abuse.
As long as pressure rises with rpms and I would not worry. Consult with your engine builder on what oil they recommend for your application.
Old Mar 27, 2011 | 03:27 PM
GMouldy's Avatar
i'm running 10w30 in her right now. I'm going to buy a new oil pressure sending unit and see if that helps or not. But yes old pressure does rise with rpm's just sitting still it dips awefully low.
Old Mar 27, 2011 | 05:59 PM
Orangemagic's Avatar
I think gm specs for good oil pressure is 1.5lbs per cyl. If its a lt1 car I wouldn't worry about it cause every one I've ever worked on had low oil pressure.
