procharger newb few questions
Old Mar 19, 2011 | 01:19 PM
346lsi's Avatar
Default procharger newb few questions
recently purchased procharger d1 for my 98 camaro it is currently setup with ms3 and stage 2.5 5.3L heads and stock bottom end.
are these heads ok for f/i application?
what camshaft do you reccomend?
rod bolts and head studs any other suggestions?
how many pounds is safe?
what size injectors ?
is a racetronix walbro fuel pump w/hotwire kit enough?
any feedback greatly appreciated thanks
Old Mar 19, 2011 | 03:01 PM
LS1RedZ's Avatar
The heads will be alright. Id go with the EPP blower cam if you really want to do a cam swap. Id run about 8lbs on that setup and 60lb injectors will get you there. The Racetronix kit with hot wire kit will be good, but not much after that.
Old Mar 20, 2011 | 06:53 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Thanks, here is a link to this camshaft. http://shop.brutespeed.com/Comp-Brut...n-Camshaft.htm Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Mar 21, 2011 | 01:59 PM
346lsi's Avatar
any more suggestions?
Old Mar 21, 2011 | 02:32 PM
fatmat80's Avatar
What exhaust are you running? The more free flowing the exhaust the less boost you will net. Is your motor forged? What are you power goals. These are all things to consider when going FI. I had to learn the hard way thats why I am asking.
Old Mar 21, 2011 | 03:27 PM
346lsi's Avatar
i have hooker longtubes off road y pipe and magnaflow cat back, stock bottom end, i would like to see 550 not sure if this is realistic with stock bottom end
Old Mar 21, 2011 | 05:01 PM
SnIpEz's Avatar
If you're considering upgrading the rods and rod bolts, do the pistons as well. Pointless to have one without the other. Once you have those in place you can REALLY turn up the boost.
Old Mar 22, 2011 | 07:55 AM
LS1Tech Sponsor
Thumbs up
With 8 psi and our cam, you can see 550 rwhp with a stock bottom end. Bob
__________________
Old Mar 24, 2011 | 01:46 PM
346lsi's Avatar
can i run stock dampener or should i upgrade to ati unit?
Old Mar 24, 2011 | 01:48 PM
LS1Tech Sponsor
If you are using an eight rib kit you need to use the ATI Performance Products 918853 balancer. If your kit is a six rib you use the factory balancer.
Here is an older copy of the ProCharger installation instructions that a customer of mine at the old shop put on the internet.
http://www.ls1.com/ed/procharger_owners_manual.pdf
The balancer pn# on the instructions has been superceded by the 918853. Bob
__________________
Old Mar 24, 2011 | 02:15 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
I'd look into different heads. Your compression is pretty high right now as is for FI- especially on the stock bottom end. Get some cheap 317 or 035 heads from a 6.0L.
Old Mar 24, 2011 | 03:15 PM
BLNLS1/RX7's Avatar
Hes Correct.
Old Mar 24, 2011 | 03:17 PM
346lsi's Avatar
i was curious about that i believe with the 5.3L heads im at 10.5:1 what would it be if i went to 317's also do you just run them stock or ported with bigger valves? thanks
Old Mar 24, 2011 | 03:22 PM
346lsi's Avatar
thanks bob i noticed on installation instructions it says 99-02 whats different in the kit for a 98
Old Mar 24, 2011 | 03:42 PM
ChevyChad's Avatar
For your HP goals, ported would not be necessary. I would however use better springs for sure. I'd have to do the math to give you an exact answer, but IIRC the 71.5cc chambers of the 6.0L heads would give a stock LS1 a compression of something like 9.5 or so.
Old Mar 31, 2011 | 10:26 AM
346lsi's Avatar
guys thanks for all the input i just have one more issue to figure out which is my compression ratio and stock bottom end i believe my compression ratio is 10.75:1 currently with the stage 2.5 5.3L heads is this to high for 8psi? is it worth switching to 317's ? on stock lower end rather be safe than sorry thanks
Old Mar 31, 2011 | 08:18 PM
Monte4ever's Avatar
Most try to achieve a 9.5 to 10 compression ratio.
Old Apr 1, 2011 | 05:49 AM
LS1Tech Sponsor
A lot of stock LS2 (10.9) engines are at 8 psi of boost with no problems at all. Bob
__________________
