Trans AM APS TT owners come in
Let me know if you have any more questions.
For cooling had some issues when running my air on around town. I did a bunch of stuff but was still having some issues. I had 160 stat fans set to turn on at around 160,I have higher flow water pump and Ron Davis rad. Temps could still get up there around town with air on.
But few factors might have been not helping. Went to 408 iron block , didn't get the exhaust manifolds or turbo exhaust housings coated and had flaw in one factory turbo so wasn't running any water cooling to the turbos.
Also transmission cooling lines thru the radiator in addition to auxilary cooler.
This season going to see how things are with new aluminum block engine. Will be sending away those exhaust manifolds and turbo housings for coating. Will be running water cooling to the turbos. Still run higher flow water pump and the 160 stat and still have fans coming on low.
May not run the trans cooling thru the radiator just go to bigger/better trans cooler or coolers.
Hoping after all this can drive the car in hot weather 90 to 100 degrees in city traffic with air on. If not then might consider removing the air from the car. Don't use it all that much.
And I have the factory air dam in the car. Also been considering think its called a burhart bumper support that may help as well but didn't want to change the radiator to vertical. Was also wondering if maybe still can run pushers or better fans .Running factory fans ,wish someone would make a nice shroud with higher flow fans that would bolt on like factory.
Where you located ?
Warren
