Which Plugs?
Old Mar 27, 2011 | 03:06 PM
BigBadWhitey's Avatar
Default Which Plugs?
Hey guys, just looking for some info.
Im setting up a procharged Lt1, and ive got a set of TR6, TR65, and TR55 plugs laying around. Im looking at 5-6 pounds of boost, what would you recomend i run?
Thanks
Old Mar 27, 2011 | 04:14 PM
Adam86's Avatar
TR6s should do just fine.
Old Mar 27, 2011 | 05:17 PM
Orangemagic's Avatar
Tr6 will work just fine.
Old Mar 27, 2011 | 05:26 PM
93formto98T/A's Avatar
Another recommendation for the TR6
Old Mar 27, 2011 | 05:49 PM
willizm's Avatar
Yup, TR6's for that boost level. If you jump up to mid teens some day then i think the BR7fs is pretty widely used for those levels.
Old Mar 27, 2011 | 06:44 PM
Adam86's Avatar
What boost level are TR6s good to assuming good IATs?
Old Mar 27, 2011 | 07:01 PM
speedsk899's Avatar
I agree with above posts. I would say once you hit mid teens you should go a second step colder. I run a TR7 at 15lbs
Old Mar 27, 2011 | 09:05 PM
Ok awesome. Its going to be A2W if thats going to matter to much? But the TR6's are in. Thanks guys!
Old Mar 27, 2011 | 09:17 PM
Adam86's Avatar
A2W for 5-6psi?
Old Mar 27, 2011 | 10:50 PM
Yeah, its not a build thing, its a "i dont want to hack apart my bumper support" thing.
Old Mar 27, 2011 | 11:15 PM
Adam86's Avatar
I would urge you to consider having something like this built if cutting into the bumper is your primary concern.
Better than the stock bumper and allows for A2A intercooler mounting. An air to air intercooler would suit your needs MUCH better than an air to water one at those boost levels. The vast majority of people with FI will never see the levels needed to justify an A2W setup.
Old Mar 27, 2011 | 11:24 PM
But for the price and easy of space/instal, a small a2w will work for me just fine without having to do that.
