vortech Maxflow Mondo Bypass Valves
OK I have an LS1 automatic, LS6 intake, 85mm TB, 60lb Injectors, P1SC intercooled, and 255lph fuel pump. This is my first ProCharger and it started and ran strong after I figured out the injector trim. When I gave it some throttle it wanted to die unless I went slowly. My AFX was reading about 12.5 and I wasn’t seeing any boost. My vortech Maxflow Mondo Bypass Valves stays open at idle and closed when I pull the vacuum line off, but will not shut without pulling the vacuum line. My questions are, dose the bypass valve need to be at a certain throttle to shut? Could it be a bad spring in the bypass valve? I have the vacuum hooked in the front of the LS6 intake just after the TB. I am also not seeing any boost. Even after I pull the vacuum line. Any idea where I went wrong?
