How to keep heads down?
Old Feb 19, 2004 | 12:39 PM
Noyzee's Avatar
8 second mod
Default How to keep heads down?
It hasnt happend yet, but im hering anything over 650-700 rwhp look into the lifting problem. how is this solved? Bigger studs, diferant gaskets, more tq on the studs?
Just curios incase it hapens.
Old Feb 19, 2004 | 01:41 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
<--- 746rwhp
-6.0 heads
-6.0 MLS head gaskets
-Custom head studs that Chris from APE knows how to order
-$1500 fuel system
Old Feb 19, 2004 | 02:17 PM
Texas Terminator's Avatar
may want to think about o-ringing them too. just a thought.
Old Feb 19, 2004 | 02:26 PM
y2khawk's Avatar
over 800 here
normal ARP studs, OEM MLS gaskets, 6.0 heads, good tune
Old Feb 19, 2004 | 03:06 PM
MIGHTYMOUSE's Avatar
775 here (********* limited)
standard size arp studs
stock 5.7 head
cometic stock replacement gasket.
good tune
Old Feb 19, 2004 | 04:34 PM
Noyzee's Avatar
8 second mod
OK, so i guess its the luck. I have the arps already, and a good fuel system, and a good tuner so I hope it works out.
i'll be using cometic or another hush hush gasket.
Old Feb 20, 2004 | 06:38 AM
smokinHawk's Avatar
it seems now that people have had more knowlege in tunning that this isnt a problem
like Rob said his heads used to warp at over 700rwhp in his old Z
but now is using stock head gaskets and studs and hasnt had that problem with his new build of his Z or formula, both which have more HP.
Old Feb 20, 2004 | 08:45 AM
Noyzee's Avatar
8 second mod
we shall see what happens. Im going up a bit with boost i think.
Old Feb 20, 2004 | 04:56 PM
if regular gaskets and studs can't hold it down, something is wrong...too much timing, not enough octane, too much exhaust backpressure.. anyone else think something like that?
mat your tq number is a little dissapointing..
Old Feb 20, 2004 | 11:02 PM
TwnTrboCE's Avatar
I was using stock head bolts and Felpro gaskets. With 12psi I had no issues. Tuning is everything.
Now going to ARP studs, o-rings, and stock MLS gaskets. Looking to run 15+psi in one car and 20+psi in the other. If we have any trouble with that we have a backup plan.
Old Feb 21, 2004 | 06:52 AM
ws6rufus's Avatar
Dont you have to use graphite head gaskets with o-rings?
Old Feb 21, 2004 | 07:13 AM
2001WS6Vert's Avatar
What torque is everybody using? I felt the 70lbs. that ARP says to do is a little light. But thats what I used anyway. Should I look at retorqueing now that its got some miles on it?
Old Feb 21, 2004 | 07:14 AM
BOO HOO BRIAN's Avatar
PSJ Wannabe & Attention Whore
L-19 head studs will work.
If you use o rings, a graphite or copper head gasket is a must.
Old Feb 21, 2004 | 10:22 AM
Noyzee's Avatar
8 second mod
I e-mailed you on the studs?
I have seen many people over 700rwhp push water. sometimes not on the dyno, but as soon as it hit the track it would push a bit.
I have a plan for mine and we shall see what happens.
Thanks guys.
Old Feb 21, 2004 | 11:12 AM
mine are at 80
Old Feb 21, 2004 | 11:34 AM
nope. straight copper here.
Old Feb 23, 2004 | 08:53 AM
Noyzee's Avatar
8 second mod
80, have they done any street runs on your car MM?
Old Feb 23, 2004 | 10:32 AM
i did about a year of street runs myself for about a year in a much more violent scenario for the HG's
Old Feb 23, 2004 | 12:33 PM
Noyzee's Avatar
8 second mod
You did that with the old setup. Mine have been fine this far as well. hope they stay when the power goes up
Old Feb 23, 2004 | 01:10 PM
that was my point, its not the power level (at least not yet) that has been the culprit.
