Twin 38mm wastegates with 6lbs springs in each spiking to 8 then settling....???
If I move the one to the left down at all it will hit the ground. The car(factory ride height) is VERY low. And the one to the right wont fit because the waterpump is in the way and if I go even farther the radiator. Im going to try the softer spring method. I figure if I can keep the spike even down to 5psi(with the 3psi springs) then I can program my boost controller to hold 5 in first and go up from there. And a 2psi spike is a big deal when you are trying to keep the tires planted on the street. That initial spike breaks the tires loose every time. Im sure the boost will become more stable as I go up in PSI...I just need the downlow for the lower gears so I can utilize the boost by gear.
Im gonna try the .2b springs and see if the spike lowers. If it does ill just set the boost controller to hold the spike at whereever it is in the lower gears. Hopefully once im above 10lbs it should hold stead reguardless.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
If I remember right you have E-boost2. Have you tried to adjust your gate pressure yet to make it start to open earlier? I doubt you'll notice the spool time difference. That worked for me. I'd have to go out and turn mine on to verify, but I think it was gate pressure. GP
Frank
Frank
Frank
Frank
After doing some reading..this statement seems to best fit whats going on with my car...
"Any spike in boost is going to be due to the wastegate not able to open fast enough, or wide enough to allow exhaust bypass. Essentially when you ramp up boost as fast as the stock turbo does, the wastegate doesn't open fast enough to allow the exhaust gases to reroute around the turbine wheel, which causes the turbo to spin much faster than its supposed to be spinning, and causes a spike in pressure.
As the wastegate opens fully, the spike in pressure will drop to a lower level since enough exhaust gases are allowed to bypass the turbine wheel."
Im gonna go with a guess and say the fact that I have 2 gates running off one source is causing the problem. While watching the guage and listening for the gates to open, they open really late...and as soon as they open the boost drops off which to me sounds like it isn't a slow issue with the gates but a response issue. Im going to install the 3.62psi springs in the car and see what I get minimum in 1st gear and work from there to stabilize it with the EB2.
The spike is the worst in 4th gear at gate pressure but as I up the boost the spike decreases. I turned it up a little today but set the crack pressure to 0 and left it there as I upped the boost little by little. I get a 3psi spike when set to gate pressure but only a 1psi spike when I set it to 10psi. Im sure if I up the boost to 15psi and set the crack pressure somewhere between 8-10psi that the spike would go away.
This turbo hits extremely hard on my setup which I think is causing the issue. Since ill never run minimum boost in 4th, the boost will be more controllable the higher I go if I dial it in correctly with my controller at say 15-20psi. Once I get the car back from the body shop and finish up all the small odds and ends I will report back with my findings. I have access to a few dynos in the area that will allow me to mess with this more.
#32
Did you ever solve this issue? I think I have the same gate as you and I'm having the same identical problem. 2-3lb spike at low boost and spike goes away with higher boost levels...
