Where to mount my 3 Bar MAP?!?!
Old Apr 9, 2011 | 04:41 AM
BooSSted LS's Avatar
Question Where to mount my 3 Bar MAP?!?!
I am going to be running an SD tune on my FI LS motor and I need some advice as to where is a safe place to put my 3 bar MAP sensor. Where exactly should I tie it into, what vacuum line should I tee the sensor into? And how long should the vacuum line be? I assume the shorter the better as opposed to running a longer line. Any body have any advice on this matter? Also, if any of you have any pics that you can post up for me to actually see, that would be much appreciated!!! Thanks.
Old Apr 9, 2011 | 08:24 AM
bump.
Old Apr 9, 2011 | 10:03 AM
346lsi's Avatar
I also need info on this topic post em up
Old Apr 9, 2011 | 07:39 PM
madmax4499's Avatar
what kind of manifold? where is your existing map sensor?
Old Apr 9, 2011 | 09:01 PM
It's a FAST 92mm intake. My existing one bar map is in the back of the manifold, stock location. I'm gonna leave the one bar back there to use as a plug and just connect the 3 bar to the wire harness using the harness adapter cable from caspers electronics.
Old Apr 9, 2011 | 09:32 PM
madmax4499's Avatar
ok, whay not replace the stocker with the 3-bar.
Old Apr 9, 2011 | 10:28 PM
Because the 3 bar is completely different than the stocker......
here's the stocker, and in the stock location on LS style intakes....
Attached Thumbnails Where to mount my 3 Bar MAP?!?!-map_sensor.jpg   Where to mount my 3 Bar MAP?!?!-ls1_map_sensor_loc..jpg
Old Apr 9, 2011 | 10:36 PM
And here is the 3 Bar....
Attached Thumbnails Where to mount my 3 Bar MAP?!?!-gm3barmap.jpg   Where to mount my 3 Bar MAP?!?!-t_18020_01.jpg
Old Apr 10, 2011 | 07:35 AM
C'mon anyone?! Need your guys help.
Old Apr 10, 2011 | 08:52 AM
rotary1307cc's Avatar
does the fast have a nipple on the back?
i just ran a short 6" long piece of hose from the manifold through the firewall to my MAP inside the cabin
works fine for me
