Our TT kit is FINALLY done.....
My goal when I started this was to give the customer a kit that would offer them the most
flexibility in turbo choices to meet any power goal from a stock motor to big cube monster, while leaving the cooling system and AC unobstructed and in it’s stock form, and not affecting the outer appearance of the car in any way, for example, cutting the bumper cover and removing the fog lights.
Our target customer is someone that wants a wicked, fast, clean daily driver that they can drive without the fear of it running hot and sweating there butt off sitting in traffic and praying for the light to change and watching the temp gauge climb out of control.
The performance of a street car means more to me than laying down a big number.
It is a balance of all these things.
This kit will accept any turbo with a 60 series compressor cover (4” inlet 2 ½ outlet) with a T4 tangential turbine housing with a 3” V-band down pipe hook up or any T4 turbo with a E compressor cover (3’ inlet 2” outlet)
With a maximum of a .96 A/R on the turbine housing, the .96 A/R has about 3/8” clearance
from the starter. Any larger A/R and the turbine housing may touch the starter.
Now think of how many compressor wheel to turbine wheel combinations vs A/R you can
come up with. I think you have enough combinations to suit most any engine combination.
If your not familiar with the 60 series compressor cover T4 turbo I’ll shed a little light on it for you.
The TC78 and 76 that most of you run as a single that is so popular is a 60 series compressor cover T4.
Now for the log manifolds that has some of you concerned.
I would refer to them as fabricated manifolds, because that’s what they are.
If they were cast like the APS manifolds no one would ever question there
capabilities but the flow path wouldn’t change much, if any.
Will the fabricated manifolds make the same power as full on race headers that were optimal
for an 1800 HP max effort race motor? NO they will not.
Intercooler:
The A/W has it’s advantages and disadvantages, but given the constraints of the F-body
and my goal for the kit it is a win-win for everyone.
Most people think an A/A works like a radiator….well it kind of does.
If you have ever seen a data log of IAT’s on any forced induction car the temps start out
low and climb as the car goes down the track. And this is true for an A/A as well as an A/W system.
So if the A/A works like a radiator why do the temps go up as the car gets faster?
Well I’ll tell you why, your A/A is more of a heat sink than a radiator.
To sum it up you are putting more energy in than the 135,150,160 MPH air can remove.
I have read where some companies sell A/A intercooler with almost no temp rise at the track.
No magic in those intercoolers, you just have a heat sink big enough to absorb the heat.
Come back around and hot lap it and you will find out that the intercooler is saturated
and this next run won’t yield the same results.
The A/W is not exempt from this either. But it does have an advantage over the A/A.
This is water. Water has the ability to absorb a tremendous amount of thermal energy.
Think of it like this, the intercooler is one big heat sink and the one with the most mass wins.
With a A/W system you have the option of putting ice in the tank, something you can’t do with A/A.
Some one had concerns about the heat exchanger. It is not a trans-cooler.
It is a copper/brass heater core that is 10 ¾” x 11” x 2” thick.
Copper/brass has about twice the thermal transfer rate of aluminum.
The nipples on the heat exchanger are 3/4” and the pump is a Rule 2000.
The water tank will hold 6.2 gallons.
To sum it all up the only way to have a perfect turbo system on a wheel driven
vehicle is to have a dragster or altered racecar, other than that space constraints will force
you to compromise something somewhere.
Oh one last thing concerning the K-member design, I’ve spent over $8,000 with a patent attorney
and I don’t plan on letting any one copy it.
Sincerely,
Chris@CBR Performance Products
PS if you have any ?’s about what the kit will or won’t do call Rob.
Most of us do not drive around with ice cubes in the car.
Also, there are plenty of imports that run hotter than f-bodys and is still able to maintain consistant 1/4 miles times and mph using a/a intercoolers.
Point is, A/W intercooler should have been optional for an additional fee. It would be sad to see a waterpump failure for this a/w intercooler and watch the charge air temps go up without the owner even knowing about it.
Last time I compared a/a vs a/w, it was a significant price increase with a/w setup.
I also don't see how the base kit can include turbos of multiple sizes w/ journal bearing and still be the same price. They clearly do not cost the same when I looked through a major turbo vendor.
Rob and I have talked about selling the kit without the A/W system.
I have to go back this weekend and finish up the install.
You may change your mind about A/W intercooling for a street car after you have seen this system.
Just like the K-member, it is a new way to do things.
If we offer a different version of the kit it will be w/out any intercooler at all.
So the customer will be responsible for the intercooler and any mods it takes
to mount it.
We may put one out there on our next run to test the waters to see how it goes..
The elbows that the turbo intakes breath threw are ¼ wall forged
steel. All the plate that makes up steering rack and control mounts
is 3/16 mild steel.
I chose mild steel because it’s easy to get, can be mig welded, and it is
not as sensitive to cracking and it’s about half the price.
People think 4130 is lighter, it’s not. It’s a lot stronger so you can use thinner
tube and that’s where the weight savings come from.
I don’t see the point in using chrome if it is welded to mild anyway.
It’s the design that makes a K-member rigid not the material.
I bought K-members from every major players in the F-body game.
I was not able to do what I done using there K-members.
Things were in the wrong place.
By me making my own K-member I have 100% control over lead time,
fitment and quality control.
By the end of this summer I will have my powder coating shop up and running.
My powder coater is a great guy, but it took him 3 weeks to get my parts
back to me.
One more reason to bring as much of this kit in house as I can.
I took features that I liked from all of them to help me with this new
design and I employed my own features like the fully boxed rear mounting
point for the lower arm and the hole for the bolt tab on the front mounting point.
This hole is a bigger deal than most realize. That hole is put there from GM
so the alignment tech can put a wrench on the head of the bolt and swing the bolt
back and forth though the slot to make alignments easy.
He can push and pull on his wrench and move the control arm ¼, ½ a degree or what ever
he needs just like the factory K-member.
Thanks,
Chris.
or be misleading in anyway. To be blunt I don’t road race, I have not idea
until someone beats the crap out of this thing road racing it.
I am confident that it is as strong or stronger
than any K-member on the market today.
I don’t remember seeing a K-member dyno, so it will have to be tested.
I will say this, the K-member is about 5lbs heavier that the stock unit.
But the motor my motor mounts are lighter than the stock stands and mounts
so it’s a tit for tat on the weight.
Thanks,
Chris.
Be nice to see how much stiffer than stock it is though if you ever get the chance to tst one.
Chris.
You see untested products all the time in the aftermarekt world. And the problem with basing designs on untested products is you can endup compounding problems. If you test then you know. and if you test against stock then you KNOW your prodcut is better than stock.
Once agian not exspecting Chris to get one of these rigged up on a jig or anything (although i would love to see it done).
Thanks,
Chris.
There will be things you will like and not like.
I would rather you know all the pro’s and cons before your kit shows up
and something is not what you expected.
I know you guys have had bad luck here and there with some turbo company’s
in the past and I understand that some may be gun shy.
If I see you at the races I would like to have a beer with you
not duck and hide.
I'm not trying to start a fight but Rob and Chris are capable of taking care of themselves, plus some off the best products have had the biggest critics. We are all allowed to be critical and when this kit performs and starts selling, I bet the type of questions asked will change. I understand you feeling the need to be protective but if this kit is all they promise it will withstand the critics. I'm one of them but I'm also open minded.
too far. I few this like a for sale ad the owner of the item listed way too high. Most people read that and think, "damn that's high" others think that the seller really needs to hear their opinion about the price when 100% of the time the seller doesn't care what you think. For a couple pages that's what this thread had turned into
