Cooling setup for procharger
Old Apr 14, 2011 | 04:23 PM
02LS1ram's Avatar
Default Cooling setup for procharger
What kind of cooling setup is everyone running with a procharger. Reason I ask is since I swapped out my dual fan for the single, the cars heating up now and this never happened before no matter what the temp was outside. I'd like to add another fan but would Like hear what some of you other guys are running first.
Old Apr 14, 2011 | 04:48 PM
Gauge's Avatar
11Second Club
I have a custom front mount that restricts airflow a great deal more than the stock setup, so my case is extreme. That being said, I added the 9" Spahl fan that people usually talk about on here up in the corner of the shroud, and that didn't do much for me. I took my car to a shop and had them cut the top radiator support and then had a custom radiator built that is much thicker, wider, and slightly shorter. It is stood up more than the stocker and has two 12" fans on the back that are very powerful. I run straight water and Red Line's Water Wetter. Still the car gets kind of warm (220*F+) with the AC on in the summer.
Old Apr 14, 2011 | 06:25 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
I have an aftermarket 16" puller (not the one procharger provides with their kit), an 8" puller, and a 12" pusher on the front of the condenser. I also have a 3" griffin radiator. The radiator rubbed on the inlet hat of my procharger tho, so I put the stock radiator back in for now. Rather than fixing the griffin one, I picked up an LT1 radiator to replace it with. Still have not put it in tho.
Old Apr 14, 2011 | 09:46 PM
SRZ's Avatar
SRZ
Fluidyne rad, stock fans, EWP, 70/30 distilled/rad fluid and water wetter. Cool as a cucumber even in extreme heat.
Old Apr 15, 2011 | 06:13 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I'll bet the fan is wired backwards, which is very easy to do. You should not be having any hot engine temps unless you're in traffic on a hot day with the a.c. on. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Apr 15, 2011 | 07:57 AM
02LS1ram's Avatar
Yea I agree bob but I only drive the car once over the winter to get it tuned but it still had the twin IC at that time.( temp was in the teens) Correct me if I'm wrong but if your sitting in the car the fan should be spinning clockwise?
Old Apr 15, 2011 | 07:59 AM
02LS1ram's Avatar
Can u explain the distilled Water mix, I've never heard of that before
Old Apr 15, 2011 | 08:18 AM
ChevyChad's Avatar
PLEASE post pics of how you got the stock fans in there!
Old Apr 15, 2011 | 08:47 AM
Gauge's Avatar
11Second Club
I'm guilty of this... I drove the car home from the tuner and hit 245*F before stopping and realizing the fan was spinning the wrong way. This was, of course, the first few miles after putting the blower on the car.
Old Apr 15, 2011 | 10:01 AM
SRZ's Avatar
SRZ
Just required a little massaging, esp w/ the 12 rib setup.
Distilled water has a higher boiling point and doesn't corrode.
Old Apr 15, 2011 | 10:27 AM
ChevyChad's Avatar
Nevermind, just noticed you have an LT1..
Old Apr 15, 2011 | 11:17 AM
02LS1ram's Avatar
Was the 16" fan a spal or flexlite? I like the idea of the 12" pusher on the front of the condenser. Got some room to play with there
Old Apr 15, 2011 | 11:38 AM
ChevyChad's Avatar
neither.. I believe its a zirgo.. Got it cheap from summit, but it had a great CFM rating
Old Apr 15, 2011 | 11:53 AM
youngrigo's Avatar
I used a SPAL extreme puller fan which i believed pulled something like 2500cfm and worked good for me
Old Apr 15, 2011 | 12:17 PM
BLAKE 01 WS6's Avatar
if you are useing the spal 9" as well it should spin the opposite way of the 16" procharger fan
Old Apr 16, 2011 | 07:40 AM
02LS1ram's Avatar
I tried the 70/30 rad fuild distilledwater with water wetter. Def made a difference but still got a lil above normal after a few Blasts on some back roads. I'm goin to look into some fans next
Old Apr 16, 2011 | 07:57 AM
ramairetransam's Avatar
im wondering how warm mine will get , i have the p1 with the 16 pc fan and a 160 thermo and fresh coolant with my fan modded in the pcm and it just stays at 210 .
Old Apr 16, 2011 | 10:49 AM
Aster's Avatar
I'm using stock ls1 radiator, single Spal 16" paddle fan, do a search I have given the part number many times, and an 05+ corvette water pump. The car never gets above 200 even in the Texas heat.
