how must boost can i run?
Old Apr 17, 2011 | 06:31 PM
dragracer44life's Avatar
Default how must boost can i run?
6.8l ls3. 9.8:1 compression ratio. completly forged motor. wonder how much boost can i saftly run?
Old Apr 17, 2011 | 08:16 PM
TurboAv's Avatar
What heads and what fuel?
Old Apr 18, 2011 | 12:16 AM
SATAN's Avatar
LOL better yet, what turbo? 30psi on a 66mm turbo is not the same as 30psi on a 100mm turbo.
Old Apr 18, 2011 | 10:09 AM
trick flow heads, 93 octane. T-72 turbo. once this car hits one 1psi of boost it just goes sideways. its crazy. lol
Old Apr 18, 2011 | 03:13 PM
HydroStream6's Avatar
A T72 is very small for a 6.8L. You're going to run into back pressure problems for sure. You'll also run the risk of pushing that turbo too hard. I'd keep it under 8psi if it were me until you get into a much bigger turbo.
Old Apr 29, 2011 | 08:14 AM
well i had a t60 turbo which worked well, this t72 has 102mm compressor wheel, 1 inch bigger than the t60.
Old Apr 29, 2011 | 08:17 AM
XtremeDime's Avatar
I believe the back pressure would lie with the turbine sizing, not the compressor. That has to be an odd looking turbo with that sizing...
Old Apr 29, 2011 | 12:11 PM
KILLER-LS1's Avatar
so its like a 412ci?? my 404 was 6.7l
your compression ratio is higher than mine and I had a bigger turbo: 76GTS
My car spooled up super fast, but it wouldnt really make more power when we pushed it past 15ish PSI.... i think you are going to have some trouble with bigger motor, more compression, and less turbo.
 Michael S. Palmer
Old Apr 29, 2011 | 03:38 PM
Busy Mopper's Avatar
Subscribed lol
Old Jun 24, 2011 | 07:49 PM
its a 416 ci. and my t72 i bought is great.
Old Jun 24, 2011 | 08:18 PM
tripblackls1's Avatar
What are the actual specs on the turbo and what brand
