turbo timing
Old Apr 18, 2011 | 04:52 PM
buick_lsx's Avatar
Default turbo timing
How much timing do you guys run down low, say 4500 or less?
When at max boost my car is at 15 degrees of timing, but I also leave the line with full boost on the trans brake at 3500 rpm...car just seems sluggish.
Should I try more timing down low for the launch but still ramp it back out before peak TQ to help with the 60's?
Old Apr 19, 2011 | 02:08 AM
buick_lsx's Avatar
Anyone? I know my car should do much better than 1.6x 60's launching with 9lbs
Old Apr 19, 2011 | 10:47 PM
buick_lsx's Avatar
Cone on...or is this a lil trick / secret that tuners like to keep to themselves??
Old Apr 20, 2011 | 08:08 AM
TracyRR's Avatar
my tuner has a ton of timing in mine down low and out of boost.... around 38 degrees out of boost and then when boost starts coming it he pulls timing pretty fast. It may only have 25 degrees or so at 1 - 3 pounds of boost. I hope this helps.
Old Apr 20, 2011 | 03:05 PM
buick_lsx's Avatar
I build boost pretty fast so that isnt the problem, by the time i light up the 2nd bulb and hit the TB i have bull boost in 1 sec probably
i just cant figure out why it wont launch and was seeing if this might be a cause...My car made 562rwhp on 9lbs and since i leave on 9lbs off the TB i figure it should do alot better than 1.6x 60's compared to what alot of others on here pull off
Old Apr 20, 2011 | 03:49 PM
TracyRR's Avatar
I understand now.... if it is hooking up, that does seem real soft. what does it flash to when you release the TB and what gear/tire/trans is in the car?
Old Apr 20, 2011 | 05:37 PM
lt170chevelle's Avatar
If its sluggish add some timing till ya get knock then back off
Old Apr 20, 2011 | 05:51 PM
buick_lsx's Avatar
yea, not spinning at all. I dont know what it flashed to, once i stage i dont look at the tach lol, just hold on and shift.
Its a fmvb 4l80, 28in tall tire, and 3.54 gears.
I plan on buying hptuners this year so i can log exactly what happens on every run to help get this thing faster and faster.
Old Apr 20, 2011 | 05:57 PM
buick_lsx's Avatar
any clue to when i should back it all out? right after the launch or...
im still on a stock longblock so i dont need any knock killing my pistons lol, peak torque is at 4600 but my torqe is basically a flat line on the dyno sheet
