Magnafuel pump suporting 2000hp.. wich one?
what hub part number is the one i need for the ATI balancer. where can i find the pulley ill be missing on the balancer hub and belt. dose it matter how many teeth they have ill be ordering this kit with braket and pulley from aeromotive.
i might just have room for the belt driven system down at the motor plate
Why do all the belt drives run small cogs ? Any reason why 5/6rib multi rib couldnt be used ?
ie. Use the inner a/c portion of the pulley and get a suitably sized pulley for the pump..
What size line from tank to pump is required with the mechanical pumps ? I assume the pumps have a good ability to suck ?
