Magnafuel pump suporting 2000hp.. wich one?
Old 04-21-2011, 12:31 AM
mike06tork's Avatar
Default Magnafuel pump suporting 2000hp.. wich one?
my weldon fuel pump gave out and its probably rebuildable but i want to try sumthing diffrent.. im thinking magnafuel MP-4701 2000hp pump but there a hole bunch to pick out. so im wondering if sum of you guys are running one of these sukers and what model number is it. have any of you had any problems with any of this name brand pumps, thanks
is 10an line in and 8an out enough for this pump of will i need to upgrade so it can last
options i have but undecided on wich one...
both Swiveling electric gear pumps
MP-4703 - 2,500+ 20–120psi 17A@45psi #10AN in and out 9.5 x 3 x 3" 6.5 lbs.
MP-4701 - 2,000+ 20–120psi 15A@45psi #10AN in and out 9.5 x 3 x 3" 6.5 lbs.
Old 04-21-2011, 02:19 AM
00bluews6's Avatar
im running the protunner 750 MP-4703 2000+hp pump half the price
Old 04-21-2011, 03:26 AM
mike06tork's Avatar
price diffrence is only like $40 between both but they run out of diffrent amperage and that what i realy dont know about.
Old 04-21-2011, 07:04 AM
93formto98T/A's Avatar
-10/-8 will work fine. I'm actually running both the 4701 and the 4703 on my e85 setup. Smaller pump kicks on in boost only. They're quiet compared to other brand pumps of similar capacity.
Old 04-21-2011, 10:49 AM
00bluews6's Avatar
the mp-4701 is $712-$760
the mp-4303 is $480 just doesnt have a swivel head
Old 04-21-2011, 02:57 PM
The Beast's Avatar
I'm running the 4303
Old 04-21-2011, 04:59 PM
mike06tork's Avatar
i guess im gona go with the mp-4703 2500+ hp pump with 17A@45psi
Old 04-22-2011, 12:55 AM
8 Second Truck Club
Blown06's Avatar
How much will HP will the 4703 support on methanol forced induction?
Old 04-22-2011, 01:40 AM
mike06tork's Avatar
well it says alcohol and gasoline racing fuels 2500hp but it dosent says anything about methanol. the guys at magnafuel recomended the 4703 today so im ordering one first thing in the morning
Old 04-22-2011, 08:01 AM
dreamls1's Avatar
anyone know how much HP these pumps will support on E85? same as Alc?
Old 04-22-2011, 10:34 AM
jasond26's Avatar
I have a similar setup and am in the process of building my fuel system. I have called around to some of the fuel pump suppliers (aeromotive, magnafuel etc.) and they all have pumps that will support that type of volume but not for sustained amounts of time. I don't know about you but I plan on driving mine on the street for local cruises or car shows and wanted something that would support that. E-85 is the main factor and because of the large amount of volume needed I think mechanical would be the best route. The larger electric pumps are only ment for 30 minute intervals at those horsepower levels.
Old 04-22-2011, 10:39 AM
Avengeance's Avatar
I sent an email to Magnafuel with questions about streetability for a e-85 high HP setup.... they replied with the 4303. So thats what Im building with... we'll see how it goes.
Old 04-22-2011, 11:51 AM
dreamls1's Avatar
Great! I was thinking of going belt drive pump, it just doesnt look easy to mount up!
Old 04-22-2011, 02:42 PM
6 Second Club Moderator
LASTLS1's Avatar
I run a magnafuel EFI 750
Old 04-22-2011, 06:14 PM
ta02zx10r's Avatar
Is anyone successfully running a 4301 on the street without heating issues? I'm sure I'll end up with one but I don't want to deal with the cavitation b.s. and overheating that goes with this setup on the street. Would a pump controller be the ticket or would I have to have a fuel cooler as well? Sorry to highjack.
Old 04-22-2011, 07:10 PM
Tiago's Avatar
Ive ran a 4303 on the street on a couple of cars, one failed after about 3000 miles...unknown reason. The other has about 1000 miles on it still good.
Old 04-22-2011, 08:21 PM
00bluews6's Avatar
4303 will be fine on the street no controller necessary
Old 04-22-2011, 09:23 PM
The Beast's Avatar
rotary1307cc on here is
Old 04-22-2011, 09:59 PM
7 Second Club
Phil99vette's Avatar
I'd do a belt drive for that much fuel in a heartbeat.
Old 04-23-2011, 03:00 PM
LS1NOVA's Avatar
Run a big cooler on the return line (think trans cooler) with -8 fittings. Bigger the better.
Quick Reply: Magnafuel pump suporting 2000hp.. wich one?
