Anyone with experience on the TT Street Kit?
As long as the car is moving and it isn't 130 deg outside you should be able to extract heat from the intake charge.
You will always remove heat, i agree with that... but a large enough amount so that the intercooler can still be deemed effective... that's where the difference is.
You will always remove heat, i agree with that... but a large enough amount so that the intercooler can still be deemed effective... that's where the difference is.I believe the ATI is ~95% efficient, at least from the temperature readings that have been posted on here. From pics that have been posted it doesn't look like the intercooler is in the best spot but it does its job well.
I didn't use an intercooler on a truck running a Vortech @6#'s, but then again it was running off of alcohol and had a low static CR.
Depending on the road course, speeds of 100+mph can easily be reached and there would be more than sufficient air flow to cool off the intake charge. I would think most manufacters out there would place the intercooler where it has a chance of getting some airflow through it. Unless you are running some rediculously high boost I don't think you have to worry much at all about heat soak on a road course.
.02
I have the 3" DP, and TT's new cross over that I havent gotten yet. and a large custom made spearco intercooler goof for like 1200FWHP. it blocks the radiator pretty good so im a little worried about that but well see.
once i get that cross over pipe here i am going to get it on and start her up. im shooting for 15psi, i want to see what this kit is capable of. im not going to dyno like rob has, but set it upand see what shell do.
I also have the alky kit, and a th400 with 12-bolt so ill loose a good bit of power through the drive train, but should make that back up in 60' at the track.
ill keep everyone posted
thanks
ed
with that TH400 im sure you get some low times, should be at low tens
As far as why nobody is making the power we are with our kit....we are the only people running a T76! Everyone else, with the exception of one person (who deoesn't/won't post here), is only running the T63...as far as I know.
FWIW, we made 500rwhp on pump gas within the first 5 dyno pulls after installing our turbo kit. And 570rwhp within the first 20 pulls. As soon as we put new valve springs on, we immediately jumped to well over 600rwhp with a stock engine. We hardly need anywhere near 150 pulls to duplicate our current HP levels. Those pulls were called "baby steps".
there is about 5" at the base for air to get through, I am going to run some ducting up there.
Im hoping to dyno close to 600, and wouldnt mind busting into the 9's high ones. I may step up to their larger log manifold if I cant see my power levels.
i just want that pipe from them its been over a month now
ahhhhh
ed firebird455@onebox.com
Rob appearantly knows how to tune a turboed car or his shop demo wouldnt be running as many dyno runs as it has already. Good job, I remember when yo first put that kit in the other car and your first "I tuned it first time using Edit" post.
I have talked with George at TTi and they do have a 3" DP option. They redesigned the manifold, the ports match, welds are complete and material is improved. Tubing is sized right and the IC is/has supported 800rwhp. I am sure, as I originally asked before, that noone has pushed this kit to its limit as it is now.
Yes, 2yrs ago the TTi Street Kit may have had problem (I am not saying it did as I never personally had one), but damn ppl, that was 2yrs ago. You think Rob woke up one morning and said, "gee I am going to make a turbo kit and its going to put down serious Dyno #'s on a stcok engine and and and and and....." ? No, he came out with a kit that addressed the downfalls of a then problemed kit, and as we have all witnessed following the posts, he has grown as a tuner, and developer. This doesnt take away the fact that the TTi kit is capable, and could be much more than what some are pushing it to. Thats why I posted this. I want to know, since the revisions to the kit, has anyone had the same OLD problems: Manifold cracking (I hear the answer is no), the ports being misaligned (heard it was fixed), the DP being made optional to a 3" (should be more than enough), tubing (that too) and the IC efficiency-still got no answer on the %, but again was told it is capable. Now, I too would like to see this kit with a T76 and the 3"DP. I will be talking with George about shipping my car there while I am deployed to hook this up, get the power I want and or redesign a race kit that keeps the AC.
thanks for the info.
Charlie.
oh on pump as well, with no alki.
also ive been looking at my engine and think they could move the altinator up like the street kit and movve the AC were the altinator used to be.
Smokinhawk...that griffin intercooler you are getting, will it bolt right up using the intercooler piping from the TTi kit?
I have the T60-1 kit and had no problems out of it yet. Anyone upgrade their wastegate to a better one? The Deltagate isn't gonna cut it when I get the T76 and up the boost to 12-14lbs.
the inlet/outlet for the TTi IC are angled, the Griffen straight.
im not goign to be putting it in the same spot either, placing it were the bumper support is like PSJ's
your right on the wastegate, defintaly need a bigger one.
"[/QUOTE]Ask yourself why TTi made a race kit when they already have a kit out with that 800fwhp intercooler and "t-76"[/QUOTE].
Umm, more efficent and the potential to make over 1000hp
The street kit was only desined to run up to 600hp efficently. After that backpressure becomes higher then it should be. But that don`t mean it won`t make more power.George told me he had a guy with his street kit that was making 670RWHP @ 13psi and race fuel, with his new log and the T76 upgrade. He wouldnt get to far into it but he did say it was a fully built low compression motor.
Even then there is natural convection occuring.As long as the car is moving and it isn't 130 deg outside you should be able to extract heat from the intake charge.
A good example of 100% Efficient I/Cs are those used in off shore racing..where Ocean water can be used to cool the charge to lower than ambient..
I would suppose that TTi finally (after MANY years) made something that works better, with seed money from a Va. sucker. It certainly paid off, no question. George wasn't going to go out there with his own money though. Certainly, he never did until someone called out his current kit. The bottom line is that George's kit still hasn't shown anything more than the log kit (choked out as it is).
His newest kit is great, and I would love to display it, but, without knowing the costs (absolutely on a 2x magnitude of that which I spent) I can't see how the money would be warranted. If I lost (and that's a BIG if), I wouldn't be sorry when I spent half, or less, the cabbage that Va.-boy spent.
SC-
http://www.turbotechnologyinc.com/ls1_race_system.htm
[joke]p.s. i want your wife and your daughter out of my house by tonight![/ joke]
