Anyone with experience on the TT Street Kit?
Old Feb 21, 2004 | 02:49 PM
CAT3's Avatar
Restricted User
Default Anyone with experience on the TT Street Kit?
Looking into getting my FI on when I return from Afghanistan and not so sure I want a high power system, or one with longevity under its belt. Seems the TurboTechologyInc Steet Kit has been out for a while and figure it must be reliable. I know FI has made leaps and bounds improvements since the street kit came out as well, mostly in tuning and fuel delivery. So, anyone currently running this kit, please let me know what your experiences and thoughts are with this kit.
Thanks,
Charlie.
Old Feb 22, 2004 | 02:37 AM
WS-6_2002's Avatar
TT sucks Just ask me and andrew! Bad customer service and the $@#$kept cracking, oil prob etc.
Old Feb 22, 2004 | 12:05 PM
MYTURBOT/A's Avatar
TTI is a good kit and most people along with me have recieved great costomer service. there new kits are high quality and don`t have the same repeated cracking problems, due to a new improved log design. The kit with the t76 turbo should put you in the 450-500rwhp range.
I`ve sat on the phone with George for hours talking about mods and upgrades for the kit. Thats great costomer service IMO when a vendor sits on the phone and basicly shoots the **** with you about Improving the performance of there kit. I had my intercooler start leaking about a year and a half after i bought the kit I mentioned it to george during one of our conversations and he insisted i send it back to him so he could fix it all i paid for was shiping there and back. He also had it back to me in three weeks.
Old Feb 22, 2004 | 12:08 PM
MYTURBOT/A's Avatar
My old kit has not cracked since i opened up the bolt holes on the manifold and cut the flange between the center ports.
Old Feb 22, 2004 | 08:01 PM
black_z's Avatar
TTT im interested in this kit as well
Old Feb 23, 2004 | 12:31 AM
CAT3's Avatar
Restricted User
WS6 2002, who is Andrew? I have heard about the log manifold cracking issue but was under the impression that was resolved now, on the kits that are being shipped out today. Also, never heard anything about oil leaks, can you clarify?
MYTURBOT/A, by opening up the bolt holes, you referring to the ones that mount the manifold to the head? And open as in oblong them or what? Is this still an issue on the new kits?
Would this kit have it in it to make more than only 500rwhp? Maybe 600 at least?
Thanks.
Charlie
Old Feb 23, 2004 | 01:49 PM
MYTURBOT/A's Avatar
Yes the bolt holes that bolt it to the head. They say the holes should be big enough to allow expansion when using a log style manifold. I don`t know if there doing this with the new manifolds but if not it`ll only take 5 min with a drill to do it. The new kit should be able to do over 600rwhp with the T76, a good tune and about 9-10psi, but you`ll most likely be pushing the stock internals. I`ve never had mine leak a drop of oil i`ve never heard of a oil leak problem. If all the connections are installed with a thread sealer or silicone you won`t have any problems.
Old Feb 23, 2004 | 03:55 PM
cablebandit's Avatar
Unless the intercooler has been changed to a better flowing and more efficient one, it isn't going to make over 600rwhp easily....and especially with only 9-10 psi.
Old Feb 23, 2004 | 06:29 PM
MYTURBOT/A's Avatar
Has anyone switched intercoolers to see if theres a performance gain?
Old Feb 23, 2004 | 06:38 PM
better yet...bypass the intercooler all together with some rubber hose. I wish I woulda tried that...cheap simple experiment. Not to be an a$$ but George always claimed that intercooler was good for some high hp....i think like 800 or so but didn''t use it on his race kit.....wonder why.
Old Feb 23, 2004 | 08:15 PM
RICE ETR's Avatar
Turbo Addict
I have seen it do ~800flwhp (which is what i think he was quoting) on a mustang kit before.... but i dunno exactly how much better the air flow is through that same intercooler on the front of a fox body stang. I guess the main thing is quick blasts of WOT, not road racing type instances where the intercooler would get heat soaked.
After a certain point, i think it would be beneficial for these street kits to just remove the intercooler and run some sort of alky/methanol injection. That would save a little $$ on the kit's cost and free up the system.
Old Feb 23, 2004 | 08:20 PM
RICE ETR's Avatar
Turbo Addict
the core sizes are pretty similar if not the same, the larger endtanks just block more of the radiator.... from what i hear.
Old Feb 23, 2004 | 10:55 PM
MYTURBOT/A's Avatar
FWIW george uses the same intercooler on some of his mustang kits that are making big power. I still think that the only reason that we are not seeing the insane numbers with this kit is because nobody is pushing it. If somone was making 150 dyno pulls like robs kit and putting hours upon hours of tuning into it, the tti kit would be make huge power also. Ok think of it this way. other then robs shop cars, how many people are making huge numbers with the QMP kit?
Old Feb 23, 2004 | 11:02 PM
MYTURBOT/A's Avatar
And i`ll bet that the reason george is using the water to air cooler is not becase it won`t flow enough, but becase he didn`t want to block the radiator and cause overheating problems.
Old Feb 23, 2004 | 11:50 PM
CAT3's Avatar
Restricted User
MYTURBOT/A, I guess it would be possible to get the street kit minus the IC and order one from Griffin or someone. I am considering running a SMC Alky kit, not for the tune aspect, but for more efficiency at the track. Also thought about using an N-tercooler with CO2, but cant tell yet as I am still in the design phase.
Guess I will email George and see about these things and let everyone know. I thought that there would be quite a few ppl running this kit, oh well.
Charlie.
Old Feb 24, 2004 | 12:21 AM
SScam68's Avatar
As long as there is air crossing the fins (i.e. the car is moving) and the temperature of the air is colder than the surface temp of the fins there will be heat transfer. The greater the temperature difference, the greater the heat transfer.
Old Feb 24, 2004 | 05:39 AM
smokinHawk's Avatar
im working on doing that now,
now just if my intercooler would come in.
Hurry up speed inc/Griffin
and when i called turbotech to find out how much their intercooler cost they'd charge you 800 for it, while you can pick up the much better griffing intercooler for 470
Old Feb 24, 2004 | 09:43 AM
RICE ETR's Avatar
Turbo Addict
correct.... however if you have more heat being put into the intercooler than the ambient air moving across it can dissipate, well then you have an intercooler that will become heat soaked. There is nothing wrong with the intercooler itself, the main issue is it's placement on the F-body front ends, which does not provide as sufficient airflow as the mustangs do, not to mention the heat from the radiator when sitting in traffic or staging lanes.
Old Feb 24, 2004 | 09:47 AM
RICE ETR's Avatar
Turbo Addict
and MYTURBOT/A...... i have been saying the same things you just said for awhile now.... why? because i agree
Old Feb 24, 2004 | 10:47 AM
SScam68's Avatar
Your car would have to be sitting still and you would have to be revving the engine pretty hard to initiate those conditions. Even then there is natural convection occuring.
As long as the car is moving and it isn't 130 deg outside you should be able to extract heat from the intake charge.
