ati pulley help
Old Feb 21, 2004 | 07:37 PM
Blown Ta's Avatar
Default ati pulley help
i was installing the ati pulley in the crank pulley today,on the directions it saids to make sure that the ati pulley is flush with the damper pulley.i cleaned the pulley with a wire brush but i still have a gap,about 1/8 of a inch
after i tightened it.is there anything else i can do to make it fit.or is the gap ok
thanks
Old Feb 21, 2004 | 08:03 PM
NA$TY-TA's Avatar
Maybe your crank/Balencer is warped........ i destroyed my stock one a while back when my crank bolt was backing out all the time and i had to buy a brand new one. I believe it was about a $96 bucks..... just a worst case thought.......
Kyle
Old Feb 22, 2004 | 02:35 AM
WS-6_2002's Avatar
Are you making sure all the splines on the ATI are engaged?
Old Feb 22, 2004 | 10:21 AM
Blown Ta's Avatar
splines
Old Feb 22, 2004 | 10:34 AM
Slowhawk's Avatar
LS1Tech Sponsor
thanks
I think they mean the inside(where the bolt goes through)is flush.When doing these kit's I alway's have around 1/8 in pulley to pulley and the kits work fine.
Old Feb 23, 2004 | 07:58 PM
BOOSTAT4500's Avatar
I have kind of the same question. My pulley has the gap but it doesn't seem to line up with the blower pulley. The crank pulley looks like it needs to stick out even further, like 3/8 to 1/2 an inch. Or the blower needs to get closer to the motor, but it's all ready barely off the alternator. My kit was originally bought for my 98' TA but is now on my 01' TA if that makes any difference. Any ideas?
Old Feb 24, 2004 | 07:21 PM
Blown Ta's Avatar
i only have about 1/8 of a inch pulley to pulley gap.most people i talked to say its ok,but i am going to call ati on that one.that thing a'int going in any further,i ll see how it lines up when i mount the supercharger.
then the intercoolers and its done
Armend
Old Feb 25, 2004 | 01:03 AM
sportenss's Avatar
It's not suppose to be flush aginst it, as long as the index posts are inbetween the gaps in the crank balancer your okay.
Armend
