Boost/Vacuum source for multiple feeds.
Old Apr 26, 2011 | 10:32 AM
willizm's Avatar
Default Boost/Vacuum source for multiple feeds.
So I've been reading and it looks like most people source off of the brake booster for source of boost/vacuum. I'll need to have three references for boost. One for the gauge, one for the BOV and one for the Hobbs switch(dual pumps). The wastegate I plan on running a line right from the turbo to the port on the wastegate. I'm running a standard ls6 intake.
I have one of those blox vacuum manifolds and my plan was to get a simple T from autozone and T that off of the brake booster and run it to the manifold.
From the manifold I'd have my BOV, hobbs switch and boost gauge connected.
Does this seem logical or am I missing something? Thanks for the input guys.
Old Apr 26, 2011 | 10:38 AM
Sweet_SS's Avatar
That's how I did mine. I had mine drilled and tapped for 1/2 inch 1/8 NPT barb fittings. But this is the one I went with
Old Apr 26, 2011 | 10:42 AM
willizm's Avatar
Got any pics of where you mounted the manifold and all the stuff hooked up?
Old Apr 26, 2011 | 11:37 AM
Sweet_SS's Avatar
I don't, but I will take some and post them up in a few.
Old Apr 26, 2011 | 12:41 PM
willizm's Avatar
Well here is a dumb question. Since I'm doing the !AIR mod anyway could I just use that connection on the back of the ls6 intake below the MAP sensor?
Old Apr 26, 2011 | 01:51 PM
Sweet_SS's Avatar
You should be able to use that.
Old Apr 26, 2011 | 04:48 PM
Sweet_SS's Avatar
Here you go.
Old Apr 26, 2011 | 05:13 PM
Tally TransAm's Avatar
i wouldnt reference the vacuum manifold there. i dont think youll have sufficient vacuum to get adequate response with everything your trying to reference off that manifold. brake booster line maybe
Old Apr 26, 2011 | 06:56 PM
gsxr1k2's Avatar
I ran a T right off the front of the intake(behind the throttle body down to a vacuum block.
Old Apr 28, 2011 | 09:07 PM
02SOMLS1WS6's Avatar
Where is a good place to buy these blocks? If anyone else has pictures on how they did this I would like to see them. Great pics Sweet SS, thanks.
I need to at least tie into boost pressure for my boost gauge and hobbs switch, how would you guys suggest I do it?
Old Apr 29, 2011 | 09:58 AM
gsxr1k2's Avatar
E-skank
Old Apr 29, 2011 | 10:53 AM
Sweet_SS's Avatar
http://www.vibrantperformance.com/
Old May 8, 2011 | 09:52 PM
What size T barb do I need for that brake booster vacuum line?
Old May 9, 2011 | 06:31 PM
willizm's Avatar
Good question, been wondering that myself.
Old May 9, 2011 | 06:46 PM
nahasapeemapetalon's Avatar
I have a block mounted where my battery used to mount, and a 3/8" rubber line to the ls6 manifold behind the TB on the passenger side. Think that was originally going to the valve covers, dont need that with boosted applications anymore, works great.
Old May 9, 2011 | 07:14 PM
LS1NOVA's Avatar
I believe the booster hose is 1/2" inside diameter.
Old Feb 7, 2013 | 10:40 AM
JoshuaGrooms83's Avatar
I just ordered this one of ebay
pretty nice looking kit for the price. im gonna run mine right off the brake booster hose.
Old Feb 7, 2013 | 11:21 AM
Boosted Firehawk's Avatar
What kit and how much?
link
Old Feb 7, 2013 | 11:22 AM
Anyone else have installed pix and some with hoobs switch, boost ref. Fuel psi regulator, brake booster and gauge on one?
Old Feb 7, 2013 | 02:55 PM
Camaro9969's Avatar
Wow old thread......I have everything hooked up to this block from brake booster with 1/2" T works awesome. Ebay vacuum block and nylon hose from silicone intakes.
