PT88 turbo LS6 wont pull past 5k, w/dyno graph
#82
believe it or not when i use to run juice i got a BAD NGK BR7EF out of the box from NGK. it was like it never ignited and it was just a dud. car ran like a turd on 7 cylinders and shook real bad but never really threw a code.
#83
I really hope its just a plug issue and you get everything going soon. Still interested to see what fixes it!
#84
UNDER PRESSURE MOD
Not that I have an FI setup making massive hp, but I did have a similar plug issue. I have swapped headers, put in new plugs and the car felt really flat. Finally found the bad plug after popping the hood at night with no lights on. I could actually see the plug arcing through the cracked ceramic.
#85
I dont remember. It had "ordered" high end plugs in it......and I put in the first thing I could find that would fit the brodix heads. They were 4553's or something.....but it was a big block.
I can find out, as Ill have the car back pretty soon. My point was that it had no real perceptable problem. If I recall, I wanted to change them because on the dyno it seemed to maybe miss just a little around 6000. Driving it, it had no reason to make you think anything was wrong. It was so subtle I thought it was a wire probably, but plugs on it were pretty easy, so I changed them and inspected the wires.
#86
#88
We've tried several things, anywhere from 10.5 to 11.5. No impact no matter where it is.
#89
In other news, I pulled the TH400 out of the car last night and found the "snout" on the PTC converter was broken off in the end of the crank. No idea what would have caused that to happen...
Looks like I'll have to call up Tim and let him to know expect my converter for repairs.
#92
dial indicator stuck on the back of the block zero'd while the crank is tapped all the way forward, then check to see what it is when its tapped towards the back of the car?
Will that get me what I need?
#94
i dontknow why im thinking this but the 44mm wg sounds too small for a 88mm turbo? i run a 88 on a 357 and boost holds steady i use a tial 60mm gate.. wondering if something is causing a pressure build up and the gate is doing someting funny like bouncing?
#95
I don't know if its the converter or not yet. I sent it in to PTC to be inspected last night. I'm sure I'll hear from them as soon as they have a chance to cut it open.
How much boost are you running? If my 44 was bouncing, wouldn't it show in my scans? My MAP pressure stays constant...
