142mph on junkyard 5.3 .....
Old Jul 27, 2011 | 07:46 AM
  #121
hawaiifiveoh's Avatar
Truly an amazing setup, hope you get a few chances to take advantage of a few idiots.
Old Jul 27, 2011 | 07:58 AM
  #122
Mazin's Avatar
I understand. I wasn't looking for a free lunch. Your setup is very intriguing. Hope to see it in the magazines WHEN you run 9's.
Old Sep 28, 2011 | 12:05 PM
  #123
yelo71454's Avatar
Updates? Videos? Is this thing for real?
Old Sep 28, 2011 | 03:26 PM
  #124
ReApEr75's Avatar
No, it's for fake.
Old Sep 28, 2011 | 05:04 PM
  #125
skinnies's Avatar
LOL yes it is for real, no updates, we turned the car up and did some more street racing, then 2 weeks ago I pulled the motor out of it, put it back in my rx7 to get the stock shortblock record back. Same motor I had in my rx7 a yr ago that took the stock shortblock record then. I put the LTD in storage for the winter will get it back out in spring.
Old Sep 28, 2011 | 05:17 PM
  #126
atomic 6's Avatar
These engines are cheap enough can't you just buy another engine, instead of switching back and forth?
Old Sep 28, 2011 | 05:24 PM
  #127
Mean87SS's Avatar
Nice!
Old Sep 28, 2011 | 08:40 PM
  #128
skinnies's Avatar
I'll pick up another one in spring to put back in the ltd, I wasn't planning on putting the rx7 back together until the record got broken and it was the quickest/easiest way to do it. I used the converter/billet 76/etc also, plus I have to use fbody accessories so it does add up.
Old Sep 30, 2011 | 10:00 PM
  #129
transaman98's Avatar
Did I see 243's on it at the mustang f body meet?
Old Oct 1, 2011 | 12:03 AM
  #130
skinnies's Avatar
799's
Old Oct 1, 2011 | 10:37 AM
  #131
My mistake. You are right. 799's are basically the same thing as 243's though right?
Old Oct 1, 2011 | 01:50 PM
  #132
skinnies's Avatar
Yep they are the factory heads on my motor, 2005 L33 5.3 is what I have.
Old Oct 1, 2011 | 04:24 PM
  #133
Is it an aluminum 5.3 then? What all did the aluminum 5.3's come in? Trailblazer? I know you and Ryan are busy with projects and the whole 5.3 record bit but I'd like to talk to ya about putting a setup together for my 98 TA.
Old Oct 3, 2011 | 12:28 AM
  #134
BLWN1's Avatar
Where is the 5.3 record 1/8 and 1/4?
Old Dec 8, 2011 | 03:33 PM
  #135
hiway's Avatar
Love this car!
Old Dec 8, 2011 | 04:12 PM
  #136
skinnies's Avatar
Yep aluminum 5.3, let me know when you are looking to do a setup. We are booked all winter with other cars but in spring should be free.
Originally Posted by hiway
Love this car!
Thanks it is a blast, I put it away for the winter will have it back out in spring with a little different setup and will be letting the gf race it all next year.
My rx7 has the record, 1/4 is in my sig, best 1/8th is 5.5's in my rx7 also.
Old Dec 8, 2011 | 10:23 PM
  #137
1CAMWNDR's Avatar
Love the LTD. My folks used to have a 1986 LTD Crown Victoria (Panther platform though I think). This is my ultimate daily driver family vehicle dream. Love the hidden turbo idea also .
Old Dec 9, 2011 | 06:26 PM
  #138
S13LSx's Avatar
Didn't realize you were running a L33 all this time. I'm building a similar setup in a S13 nissan 240sx. L33 with a 216/221 Lunati cam and a turbo. I was thinking about the TC78 but I'm curious what you recommend. It will be a 3.55 gear 28" tire with a glide and a brake.
What are the limits of the TC78? mph wise in your RX7...
How loose of a converter do you recommend from PTC?
What does the rx7 WEIGH? I'm thinkinng ill be about 2700lbs wet with driver.
Old Dec 9, 2011 | 06:29 PM
  #139
S13LSx's Avatar
BTW nice build man. The 10-1 CR of the L33 and the E85 are getting along well together. That's what I was thinking when I choose the L33. I'm going with 96lb injectors.
What do you rev it to?
Stock rod bolts?
Are the head studs and LS9 gaskets a must if your going to push it up around 20psi?
Old Dec 10, 2011 | 06:42 AM
  #140
skinnies's Avatar
Stock rod bolts?
shifting at 6500 now, limiter at 6800, yes stock rod bolts, and yes I recommend the head studs/gaskets.
154.7 on 18lbs, made 686rwhp, for comparison w/ the billet 76 on 24.5lbs it made 855rwhp and went 167.9mph
Call Dusty Bradford at PTC and let him spec it all for you
2600lbs with me in it, could definitely be a lot lighter if we ever make it more dedicated race car, but as it is currently it's setup to drive A LOT on the street.
