turbo guys.. what kind of oil you running???
Old 06-14-2011, 08:51 AM
  #41
UNDER PRESSURE MOD
The Alchemist's Avatar
Not a turbo guy, but I know a little something about oil and I am running CAM2 20W50. I get it for free, so that helps too.
Old 06-14-2011, 05:55 PM
  #42
4SFEDZ's Avatar
Originally Posted by The Alchemist
I know a little something about oil.
care to elaborate a little?
Old 06-14-2011, 07:03 PM
  #43
headed-ws6's Avatar
The alchemist is a chemical man LOL
Old 06-14-2011, 07:35 PM
  #44
UNDER PRESSURE MOD
I used to be a formulation chemist at Sunoco. It was specifically in the gasoline market, but had some friends over at the refinery and race fuel division.
But it's been a while since I've been in that industry. I've been in Pharma for the past 10 years.
As for the CAM2 comment. My wife actually does quite a bit of design work for them and is constantly asking me to explain different things about oils.
There's some differences between oil brands, but not as much as you may think. Most companies use the same base stocks.
Old 06-14-2011, 07:42 PM
  #45
7 Second Club
Phil99vette's Avatar
Brad Penn....get the oil that suits your needs.
Old 06-14-2011, 09:01 PM
  #46
Fbodyjunkie06's Avatar
I am going to check this Brad Penn oil out. I am running Amsoil 20w-50.
Old 06-14-2011, 09:41 PM
  #47
Adam Connell's Avatar
Amsoil all the way. I've run every high end synthetic and I always come back to Amsoil. It makes my grand national happy.
For the monster trucks we either run Red Line or Amsoil, a few run Brad Penn.
Old 06-14-2011, 10:56 PM
  #48
For the other's that run Amsoil, do you guys use the Hot Rod line up with the extra ZDDP additives for motors with flat tappet cams and that are deemed "high performance"?
Old 06-15-2011, 03:31 AM
  #49
7 Second Club
10sec_rx7's Avatar
im running brad penn 20/50
it works great with the methenol!
Old 06-15-2011, 08:49 AM
  #50
SPRAYED 01's Avatar
Are alot of the 20/50 guys very loose race engines? Or are some legit street cars?
Old 06-15-2011, 07:53 PM
  #51
7 Second Club
10sec_rx7's Avatar
in my street car i run 10/40 brad penn, it runs mid 11's cam only LS1,
Old 06-15-2011, 09:51 PM
  #52
KILLER-LS1's Avatar
Torco SR5 10-40 here
Old 06-15-2011, 10:10 PM
  #53
ModularTurbo's Avatar
AMSoil dominator 10w-30 w/ RevX treatment
Old 06-16-2011, 08:03 AM
  #54
rotary1307cc's Avatar
shaeffers here
Old 06-16-2011, 11:36 AM
  #55
Compressor Surge's Avatar
If Rotella Syn 5W-40 is good enough for my Duramax, it's good enough for my turbo 6.0.
Old 06-16-2011, 04:30 PM
  #56
MIGHTYMOUSE's Avatar
ive decided to make my own oil. it will be the best because its a blend of the best.
1 quart redline, one quart rotella, one quart penn, one amsoil, one mobil 1, one vr1, one bottle of zmax, one bottle of prolong, one engine restore, one bottle of pure snake oil!
Old 06-16-2011, 04:57 PM
  #57
Snake oil!!!!!!!
I want some of that!!!!!!!
Old 06-16-2011, 05:02 PM
  #58
buick_lsx's Avatar
i think that this thread just shows many differnent oils will all work lol
Old 06-16-2011, 05:12 PM
  #59
2 please!
Old 06-17-2011, 03:21 PM
  #60
If you can add unicorn tears and a touch of unobtainium to the mix, I'll buy some, if you can keep it under $10 / quart.
Quick Reply: turbo guys.. what kind of oil you running???
