Powerdyne for my 99 WS6??
Old Feb 22, 2004 | 09:57 PM
99WS6LS1T/A's Avatar
Talking Powerdyne for my 99 WS6??
I have a guy that lives in my subdivision, that has a powerdyne supercharger for a 5.3 truck that has never been installed. I looked @ the setup and I feel pretty confident I can make this setup work on my T/A. Any suggestions from the Forced Induction Gods would be greatly appreciated.
Old Feb 22, 2004 | 10:07 PM
I had a friend of mine who's a machinest looked @ the setup. He said he can modify it, and make it work. I just first wanted some input. What H.P. increase can I look for w/ a 9lb. pulley? Or is there a 12lb. pulley by chance?
Old Feb 23, 2004 | 01:48 AM
I know someone can answer these ? for me.
Old Feb 23, 2004 | 08:51 PM
jrios's Avatar
They make a stock 6lb pulley. Anything after that you will have to have custom made. I had a custom 2.9" pulley made and on my heads and cam motor it produced 8lbs of boost. With that setup I made 473rwhp and 459rwtq.
Old Feb 23, 2004 | 09:13 PM
Can you tell me where you had the custum pulley made? Also I've heard about a kevlar internal belt so it can handle the extra abuse?
Old Feb 24, 2004 | 08:49 PM
I know someone can answer my last questions.
Old Feb 24, 2004 | 09:21 PM
Blackbird's Avatar
ASP will make you the pulley.
As for the belt I am not sure. Jrios is super busy with a new job but if you PM or email him I am sure he will answer your question on where to get the belts.
Old Feb 24, 2004 | 09:24 PM
I appreciate the info Blackbird.
Old Feb 24, 2004 | 10:54 PM
jrios's Avatar
I would recommend the fiberglass belt they hold up to the heat better from what I understand.
I picked up all my Powerdyne parts from the E-mail below he offer great prices.
ForcepowerEng@ aol.com
Old Feb 24, 2004 | 10:57 PM
Thanks, Now I have to locate a place to get it and have it installed. Once this is done can the powerdine push 12 psi.??
Old Feb 24, 2004 | 11:07 PM
jrios's Avatar
I just edited my post where you can pick it up from. I highly recommend them because of the great prices.
Old Feb 24, 2004 | 11:12 PM
Thanks jrios, Do you think I can get 12 psi. out of this s/c with the upgrades?
Old Feb 24, 2004 | 11:19 PM
Blackbird's Avatar
negative.
with your mods with the custom pulley you will see 7-8psi
Old Feb 24, 2004 | 11:20 PM
So that is the limit for the powerdine?
Old Feb 24, 2004 | 11:30 PM
jrios's Avatar
I probably wouldn't go past the 2.9" pulley. I think anything else the belt will probably break. Or at least shorten the belts life greatly. But it also depends on how high you plan on revving the motor. 6k rpms is the most I would bring up the rpms. You will find by 2500rpms you will have 5psi and at about 4500rpms you will have 8psi and than it would hold steady. At least that is what I noticed with my heads and cam setup. I would guess on a stock motor with the 2.9" pulley you will probably see 10psi.
jason
Old Feb 24, 2004 | 11:38 PM
jrios's Avatar
I never pushed it past the 2.9" pulley so I could not tell you for sure but my guess would be that is the limit where you still get driveability and your not replacing the belt all the time.
jason
I appreciate the info Jason. I plan on putting the heads I have absolute 5.7 stage 2's w/ a Futral Motorsports blower cam. Scooter
Old Feb 24, 2004 | 11:43 PM
Jason I have a set of Stage 2 absolute 5.7's that I will be putting on alond w a Futral motorsports blower cam. Scooter
