ebay turbo track results
Old 05-11-2011, 11:13 PM
eviltwin_1987's Avatar
The ad for the turbo is pretty funny
Old 05-11-2011, 11:57 PM
skinnies's Avatar
Originally Posted by lsxmalibu
bad....made 4 runs and everytime I tried to add a little to the boost controller, first was 4psi, then 5, then tried even more but 6 was all i could get. cant wait to change gears and get a good wastegate, higher boost.
You need a stiffer spring in the wastegate, it should be able to make more boost then.
Old 05-12-2011, 03:03 AM
flippincamaro's Avatar
Very nice run malibu
Old 05-12-2011, 07:27 AM
lsxmalibu's Avatar
Ya the ads are sad, there are other vendors listing it as water cooled.....
Think my wastegate spring is just too weak, barely holds 4 psi with the controller off, ill try to get a 8 psi spring then use the controller to add more.
Old 05-12-2011, 10:32 AM
Zombie's Avatar
Originally Posted by boosted LT1
I also have an LT1 rearmount that is also EBay parts but now changing to a Master Power T76.
I hope the turbine is bigger than a p-trim on that, back pressure city if not
Old 05-12-2011, 12:28 PM
boosted LT1's Avatar
It is P trim...got it cheap and compared to an EBay .84 it is an upgrade. It is a 4400 Lb lead sled...I use it as a street toy is all. Someday I may use the engine and transmission in a Monte Carlo I have. I like having a 20 mpg Roadmaster with a little umph I am hoping for just a low 12 so nothing to write or brag about.
Old 06-15-2011, 08:44 PM
MillsMotorvation's Avatar
Thank you very much!!!
Old 06-15-2011, 09:08 PM
01GMC5.3's Avatar
I was actually just lookin at a turbo very close to it
Old 06-15-2011, 10:16 PM
mpatton's Avatar
Im glad to see these results I have an " ebay " kit sorta mostly the cold piping is all that's from ebay lol well see how it all works out. Nice time btw!
Old 06-15-2011, 10:58 PM
lsxmalibu's Avatar
I followed the "gt45 clone" turbo on other forums and not one issue yet...some people have 30k miles on them...
Old 06-17-2011, 10:58 PM
I cant see video, do you have another link?
Old 06-18-2011, 07:11 AM
  #32
lsxmalibu's Avatar
works on my end if you click on the picture
Old 06-18-2011, 07:37 AM
  #33
machete's Avatar
awesome.
Old 07-05-2011, 08:43 PM
  #34
Great info. I just mounted the turbo, waste gate. What type fuel lines you run? I see everyone mount there turbo with compressor facing forword. Is that to simplify down pipe route? Can you give me info on how to make the down pipe? I have the same turbo.
Old 07-06-2011, 07:45 AM
  #35
lsxmalibu's Avatar
for fuel lines...I run the 250 PSi blue line wrapped in a plastic cover ...3/8". yes forward facing so the exhaust has a straight path backwards. FOr the downpipe... its a 3.5" v band...so order one of those, and then either use 3.5 pipe or I used 3" and expanded the end to fit in the v flange and ran 3" all the way back.
Old 07-06-2011, 12:09 PM
  #36
Is the down pipe have to be stainless, or can I use mild steel?
Old 07-06-2011, 01:19 PM
  #37
lsxmalibu's Avatar
Mild. Then I used a 3" glasspack, car is not very loud. I added a cut-out and found that it adds 2psi when I take the cap off
Old 07-26-2011, 09:39 PM
  #38
Hope I can go that fast!
Old 12-07-2011, 08:21 PM
  #39
Are the external waste gates adjustable? If so how do you adjust?
Quick Reply: ebay turbo track results
