Forced Induction Head Gasket Recomendations Here Please
Old May 8, 2011 | 07:53 AM
Hotrod God's Avatar
Default Forced Induction Head Gasket Recomendations Here Please
I am just getting in to a cam swap before I bolt on the new D1SC kit. I have everything in front of the motor off except the timing cover and am wondering if I should go just a little farther with the tear down and swap out my head gaskets from a Fel-Pro Q1041 to a Cometic TFS-30694030-051 - Trick Flow® Cometic MLS Head Gasket w/ .051 compressed thickness.
Currently my compression ratio is right around 10.46:1 w/ my Fel-Pro gasket @ .041 compressed thickness. I would imagine that the extra .010" would help lower the compression ratio a little for my boosted application. Plus I would think that the multi-layer steel gasket would also be stronger for the boosted application.
What do you guys think?
Thanks
Old May 8, 2011 | 07:59 PM
Hotrod God's Avatar
anyone?
Old May 8, 2011 | 08:28 PM
LASTLS1's Avatar
6 Second Club Moderator
Wouldn't hurt. I've used both and liked them. As long as you have it that far down my as well check them out and put a new set in.
Old May 8, 2011 | 10:54 PM
IDRIVEAG8GT's Avatar
If you're running a 4 inch bore, try the Zr1 gasket. I love them.
Old May 8, 2011 | 11:12 PM
westtexasbuff's Avatar
I'm using LS9 head gaskets.
Old May 9, 2011 | 10:25 AM
BadgeZ28's Avatar
A better move would be to swap out your heads for a set of 317 truck heads and the .051 6.0 gaskets. That will get you around 9.5/1
Old May 9, 2011 | 11:49 AM
NoGo's Avatar
A little drop in compression couldn't hurt. I've been running the same cometic at the below power level (15-17 psi) for the last 7 years without an issue.
Old May 9, 2011 | 12:07 PM
123quattro's Avatar
If you go to a MLS gasket make sure the head and block sealing surfaces are good. To get them to seal the heads need to be machined to a finish that you can see your reflection in. After that they work great.
Old May 10, 2011 | 09:31 AM
MaxxMitchell's Avatar
LS9 hands down, we run them on JY 5.3s to built 408s.
Old Aug 19, 2011 | 12:40 PM
cals400ex's Avatar
what is the thickness of the LS9 gasket? i think the 6.0L gaskets are 0.051".
Old Aug 19, 2011 | 01:33 PM
tim99ws6's Avatar
Same, it's more layers, but the overall compressed thickness is the same.
