Turbo oil return on dry sump engine
Can I "T" off from one of my scavenge lines from my dry sump pump to the drain port of my turbo? Will this work or?... I have a Jesel front cover and I'm running a alternator and the pump drive so putting a fitting at the front cover is gonna be kinda tight with the balancer and all the belts... Ideas? I could probably send my pump back and add another dedicated stage for the turbo, but I'd like to avoid the hassle if possible...
