New turbo pouring oil out exhaust ??
I have a new PT76GTSH and just started the new combo up for the first time and been messing with the tune to get it to idle. This thing filled my garage up w/ so much smoke I couldnt see the other side...lol. Also it was bubbling oil out the exhaust flange on the turbo and has a small puddle under the car.
I can pretty much see what I did...I have the drain line dropping down about 6" before it goes back up into the oil pan. I can fix this, I was just lazy and didnt shorten the line up like I should have.
My main question - Will straightening this line stop the leak? Or is the seal now trashed and need a new one?
Also.. The feed line going to it comes right off the port above the oil filter... I cant remember what size line it is... It is bigger than my previous setup I had.. How are people restricting the AN fittings? I might have some nitrous parts around.. Should I put a restrictor in it? About what size?
I hope this thing isnt fudged..
Just make sure the return is down hill all the way to the sump,
and at least -10 , -12 is better.
and ensure you have a decent PVC setup so cankcase pressure doesn't impede the return flow.
That I havnt checked.. i'll take that apart tonight and look. If there is oil in the cold side might be a contributer to the fight ive had all weekend trying to get it to idle with these 160# high imp injectors. ... never thought about oil in there...hmmm. Thanks.
Doubt im going to take the exhaust housing off and clean it though... too much work.
