Turbo hot side question
Old May 17, 2011 | 07:22 PM
Blown02Camaro's Avatar
Default Turbo hot side question
Im planning or going turbo on my camaro. Iv been asking around to see which way is easier to keep a/c, Iv heard you can run a truck manifold on the driver side and a c5 manifold on the passenger side. I was wondering has anyone done this, if so how do you like it?
Old May 17, 2011 | 09:02 PM
0269camaro's Avatar
Do a search for "C6 manifolds". There is a ton of information out there on this setup. Below is one example of a thread full of good info.
https://ls1tech.com/forums/forced-in...dy-thread.html
Old May 17, 2011 | 11:00 PM
dredoggy's Avatar
if you dont want to hassle with all of that just put it in the rear..
Old May 17, 2011 | 11:05 PM
TheLS1Lover's Avatar
^ Why? The C6/Truck Mani setup is very simple. And you don't have to worry about scavenge pumps or your turbo(s) choking on water.
Here is a build thread that uses them.
http://www.theturboforums.com/smf/in...topic=116381.0
Old May 17, 2011 | 11:08 PM
In case you don't read ^ that, the C6 manifold uses a steel o-ring to seal and its impossible to find new. The Toyota Avalon and Some Lexus models use it to seal the cat's.
Old May 18, 2011 | 07:01 PM
with this setup how big of a down pipe can you fit?
Old May 18, 2011 | 07:09 PM
hitmanws6's Avatar
Depends on the kind of k member. Stock you can fit 3.5 with solid mounts, aftermarket you can fit 5 inch
Old May 18, 2011 | 07:15 PM
^ Precisely. I don't really think you would need more than 3.5" unless your running a T6.
Old May 18, 2011 | 07:17 PM
im looking at running an 78 or 80 mm
Old May 19, 2011 | 11:03 AM
LS1NOVA's Avatar
Just a note on the C6 Manifold flange: You can machine down the manifold (or grind it) so its is flat and just uses a flat alumimum or copper gasket with a common flat flange.
